Hi Everyone,
Just to let you know we now have a very affordable solution to upgrading your fuel system for forced induction owners :)
High Capacity Fuel pump kit GT86/BRZ £110.70 + vat
246 Litres Per Hour
Simple installation
Complete with 'O' rings and in tank filter.
Also a High Capacity Port Injector Set £299 + vat
540cc (We can also supply 660, 770 & 1100 cc Injector kits, please enquire)
A complete set of 4 port injectors with wiring tails and necessary seals.
Injector sets are precisely flow matched to within 1%. Each injector within each set is individually numbered and results for each injector are listed on a detailed flow sheet included with the set.
Injectors are flow tested and rated at 43.5psi (3Bar) at 90ºF fuel temperature using CF-16B calibration fluid.
Superior short pulse width control and tight manufacturing tolerances make these injectors easy to tune and provide great driveability.
Every injector is covered against failure caused by defects in original manufacture by our 12 month warranty.
The injectors require you to change the injector plug on the wiring harness. This can be done by soldering in the pigtails (included) to replace the plugs currently on your harness. This is our preferred method of install due to limited space in the injector area. Optional plug & play wiring adaptors are available to order.
Best Regards
Adrian
