Twigman 93 Report post Posted July 16, 2014 Anyone know how to adjust the bonnet height? On the driver's side of my 86 the bonnet seems to stand too high relative to the wing. Anyone know how to adjust this so it sits a couple of mm lower? The car is going in to the dealer on friday morning so might get them to look at it but I suspect they might blame my bonnet dampers and not do the job. Share this post Link to post Share on other sites
Twigman 93 Report post Posted July 16, 2014 You can see this in the pic in this post when you click the pic to enlarge it: http://www.gt86.org.uk/forums/topic/1776-my-86/?p=25724 Share this post Link to post Share on other sites
nikndel 509 Report post Posted July 17, 2014 you sure you are not suffering from dentitus? a common ailment where you keep seeing things after having a dent repaired Share this post Link to post Share on other sites
Twigman 93 Report post Posted July 17, 2014 yes i am sure Nick...this is on the other side anyway Share this post Link to post Share on other sites
Pitman 188 Report post Posted July 17, 2014 To adjust the height at the front, just screw the rubber stops in or out. As far as the rear is concerned, I would not dare to post on a public forum how the alignment was adjusted in the body shop of Toyota :-) Share this post Link to post Share on other sites
Twigman 93 Report post Posted July 17, 2014 It's along the whole length of the bonnet Dave Share this post Link to post Share on other sites
rob275 1817 Report post Posted July 17, 2014 To adjust the height at the front, just screw the rubber stops in or out. As far as the rear is concerned, I would not dare to post on a public forum how the alignment was adjusted in the body shop of Toyota :-) I'll do it for you then, use a washer Share this post Link to post Share on other sites
