Daninplymouth 61 Report post Posted March 7, 2020 Hi, looking to make my reverse lights a bit brighter. I always thought the facelift were leds but they are not so looking for some bright led bulbs to fit. Has anyone got any they recommend? according to the book it should be a W16W but when I google this it comes up with loads and they all have different wedge types, are these all the same fitting? Share this post Link to post Share on other sites
willclarke 50 Report post Posted March 7, 2020 I used these with oem reverse light, made quite a difference!Osram 9213CW-02B LED Premium Retrofit, weiß, M, Set of 2 https://www.amazon.co.uk/dp/B01LX8OQEN/ref=cm_sw_r_other_apa_i_4C2yEbYGQ9568Sent from my Pixel 4 using Tapatalk Share this post Link to post Share on other sites
Daninplymouth 61 Report post Posted March 7, 2020 1 hour ago, willclarke said: I used these with oem reverse light, made quite a difference! Osram 9213CW-02B LED Premium Retrofit, weiß, M, Set of 2 https://www.amazon.co.uk/dp/B01LX8OQEN/ref=cm_sw_r_other_apa_i_4C2yEbYGQ9568 Sent from my Pixel 4 using Tapatalk Thanks I will order a set up. Don’t suppose you know the number plate bulb too? Share this post Link to post Share on other sites
willclarke 50 Report post Posted March 7, 2020 Thanks I will order a set up. Don’t suppose you know the number plate bulb too?Osram LED 2880CW Parking Lamp (12V, 1W) https://www.amazon.co.uk/dp/B00I798TKO/ref=cm_sw_r_other_apa_i_Wx4yEb29VFVQXCould be the same for the reverse bulbs, but I installed these the wrong side up first time, so if they don't work that could be why! Sent from my Pixel 4 using Tapatalk Share this post Link to post Share on other sites
willclarke 50 Report post Posted March 7, 2020 P.S I stole these from a build thread on here, credit due to someone else Sent from my Pixel 4 using Tapatalk 1 Daninplymouth reacted to this Share this post Link to post Share on other sites
