CA11RBZ
Burning smell coming from car.
Hi,
searched the forums and found cam plate cover leak however I’ve checked it and ran a paper towel under it and no oil is there. Also checked below to see if any dripping oil has left a mark on the overpipe and there’s nothing there. The smell appears when I accelerate through the gears topping at about 5k rpm. More so occurs when I drive up hill. Looked under the car to see if I’d picked anything up that might be burning onto the exhaust but nothing. Smell is intermittent so I can’t replicate it all the time.
many thanks
your problem is this car has a huge manifold thats not far off the same size the under tray. Couple that with every seal on engine being a liquid gasket and not a proper one little leaks are common nearly all catch the manifold and cause a smell.
Id suggest getting a mirror and stick and looking round the front chain cover they often leak there.
66608948_10157284229218788_6169490310456934400_n.jpg.813d0e16177514f6515de648da95e809.jpg
Have a look at this:
https://www.facebook.com/groups/GT86.Drivers.Club/permalink/1577705632366013/
1 hour ago, CA11RBZ said:
Thanks for that rich I’ll take a look. With the timing case leaking is it serious ?
Depends how bad the leak is. I would guess its only weeping so I would say no in that case!
