Matt100 1 Report post Posted May 17, 2019 Hey, Hope you can help. I randomly, lost all FM and AM signal on the BRZ. - CDs, USB work fine. It's still got the standard crappy green head unit fitted, and I realise after doing some reading / what research I could that the aerial is actually amiplified from a 12V pinout on the head unit itself. So, before I go throwing money at head units, is there anything I should be checking which is a "usual" culript for loosing FM and AM signal? I've checked the antenna is still plugged in to the back of the head unit which it is Cheers! Share this post Link to post Share on other sites
vanko25 70 Report post Posted May 17, 2019 Take the dash panel off, 4 bolts and take the unit out. See if the antenna cable is connected to the unit. Check your fuses for a blown one too if there is separate amp for the antenna. Share this post Link to post Share on other sites
