Adam9 37 Report post Posted June 28, 2018 I'm in the middle of fitting a tuning developments exhaust which I picked up second hand, I've got right to the end only to realise the OEM spring bolts don't seem to fit through the holes at the cat end. Does it normally come with different bolts for this connection? Share this post Link to post Share on other sites
dom2497 33 Report post Posted June 28, 2018 Does it still use the donut gasket? If so you will need spring bolt, if its just a flaaaannnnge you can use normal bolts with the necessary washers. Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 28, 2018 Still has the donut gasket so I'm fairly sure it should use spring bolts but I'm surprised the collar on my OEM bolts is about half a mill too wide to go all the way through the plate on the TD exhaust Share this post Link to post Share on other sites
vanko25 70 Report post Posted June 28, 2018 Hi Adam, You will need longer bolts for the TD. Something like M8x80 or M8x100 High tensile along with Penny washers. You can reuse the OEM nuts. I have some of these at home if you are stuck, otherwise your local Screwfix or Toolstation will have some. Bolts Penny washers Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 28, 2018 That's great, thank you vanko. So not spring bolts then? I'm surprised it uses the donut gasket in that case. I will make a trip down to Screwfix tomorrow! Share this post Link to post Share on other sites
vanko25 70 Report post Posted June 28, 2018 If you don't use the gasket it will be blowing badly from there. I used these bolts and washers along with the original springs (that's why you need the washers so the spring can sit on them). Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 28, 2018 AHH now I follow! Sounds great, thanks again Share this post Link to post Share on other sites
vanko25 70 Report post Posted June 28, 2018 No worries mate. I also grabbed some g clamps to hold the flange in place, it's just easier. Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 28, 2018 If it is the same as the scorpion system I have just fitted then you can use the springs and bolts but it was a bastard to get them compressed enough to get the nuts on. I got lucky on the drivers side with plumbers grips to get the nut on but the passengers side was harder as there isn't as much space. In the end I used a quick clamp as a spreader and used it to compress the spring with one end on the bolt head and the other against the underside of the car. A real faff but got there in the end Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 29, 2018 12 hours ago, Andrew Smith said: If it is the same as the scorpion system I have just fitted then you can use the springs and bolts but it was a bastard to get them compressed enough to get the nuts on. I got lucky on the drivers side with plumbers grips to get the nut on but the passengers side was harder as there isn't as much space. In the end I used a quick clamp as a spreader and used it to compress the spring with one end on the bolt head and the other against the underside of the car. A real faff but got there in the end The problem I had is the holes in the collar aren't big enough to fit the wider part of the spring bolt through so even without the springs it wont work. I'm going to do as Vanko mentioned but looking at the way its built I think I could just use normal bolts. The collar is loose on the mid pipe so even with normal bolts the pipe is free to rotate a little. Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 29, 2018 12 minutes ago, Adam9 said: The problem I had is the holes in the collar aren't big enough to fit the wider part of the spring bolt through so even without the springs it wont work. I'm going to do as Vanko mentioned but looking at the way its built I think I could just use normal bolts. The collar is loose on the mid pipe so even with normal bolts the pipe is free to rotate a little. ...or drill the holes out to accommodate the bolts Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 29, 2018 12 minutes ago, Andrew Smith said: ...or drill the holes out to accommodate the bolts That did occur to me but I don't have a drill bit big enough. I think the home made spring bolt solution is probably the easiest way out of this for now. I need it ready for Japfest Donnington Tomorrow! Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 29, 2018 Worked a treat Vanko, could only get 70mm M8 bolts so it was still tough to get them through but got it eventually... Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 29, 2018 Top job 👍 Share this post Link to post Share on other sites
vanko25 70 Report post Posted June 29, 2018 I got 70mm myself because I couldn't get 100mm at the time too. I think even TD use similar bolts when they are installing the systems brand new. You can spot it on their YouTube video for the exhaust. The high tensile bolts will withstand all the vibration from the engine too so it will last long time. 1 Adam9 reacted to this Share this post Link to post Share on other sites
