Guest
Tein Street Advance Coilovers, Eibach Camber Bolts & Adjustable Drop Links
Guest
Up for sale is a full set of Tein Street Advance coilovers.
They have covered about 1500 miles / 1 month and therefore almost brand new.
I will include Eibach camber bolts in the sale, which normally you'd have to buy seperatly.
Please note that that you'll need to swap your original top mounts onto these.
£370 Collected
£380 Posted
I also have some adjustable droplinks which i can include in the sale. These help bring back the ARB to the right level after lowering.
£40
They have covered about 1500 miles and therefore almost brand new.
These are currently fitted to the car, but will be removed on Saturday - weather permitting!
I will include Eibach camber bolts in the sale providing i can find the originals :lol:
£370 Collected
£380 Posted
Please note that the Perrin droplinks are not included in the sale & you'll need to swap your original top mounts onto these.
20170121_104941685_iOS.thumb.jpg.f5a9bdfc24a5128c8e6a7e29e7e20393.jpg20170121_092832926_iOS.thumb.jpg.0614fe6967e886c8e2d0eb42d989c41e.jpg
I'll update with current pictures when the coilovers are off the car.
What you swapping to @don out of interest?
Guest
I've put an order in for some MeisterR CRD coilovers!
47 minutes ago, zhuonanli said:
Hi Mate, Can you comment on the ride quality of these coilovers ?
I mean everyday use wise. it is harsher than stock?
Ride quality is great. Springs are fairly soft for aftermarket coilovers (5kg/mm all around), which is stiffer than stock, but in my experience nowhere near stiff enough to feel uncomfortable.
They require a little bit of setup however, as the damper settings can be a little fiddly to work out, but once you've dialled them in, they're great.
A few people who have experience of GT86's have commented that my setup is one of the best they've tried, most negative comments you will get about these will be from people who haven't tried them :)
I chose these as I wanted coilover with not to hard spring rate but was ride height adjustable and rebuildable plus damping rate adjustability.
The ride is firm but not uncomfortable and I have a rods in my back so anything to hard would be out of the question. I also have Tein's EDFC Active system with gps which you can adjust set up front and back by storing different settings or letting system adjust automatically.
Car gets used on road and track and very happy with set up but bear in mind ride quality can be effected by wheel size and tyre.
Guest
First post has now been update with up to date pictures. They are in a box ready for collection / delivery.
Guest
