smudge 1020 Report post Posted August 11, 2014 Probably being really thick here, but needing some help with adjusting my HKS coilovers Rears are easy, remove the rubber cap on top and use the tool provided to spin right for stuffer and left for softer I thought the front would use the same tool, but apparently not... Hex design tool: Top mount on the fronts seem to have a triangle where I thought the tool would go?: Instructions are all in Japanese, pictures really don't help either.... HELP PLEASE! Share this post Link to post Share on other sites
rob275 1817 Report post Posted August 11, 2014 PM Hashiriya, it's his kit! Share this post Link to post Share on other sites
smudge 1020 Report post Posted August 11, 2014 PM Hashiriya, it's his kit! Cheers Rob Share this post Link to post Share on other sites
Mark@Abbey M/S 235 Report post Posted August 11, 2014 It is hex drive in the front dampers. Look at your picture the hex drive is on the top edge of the adjusting hole. Thanks Share this post Link to post Share on other sites
smudge 1020 Report post Posted August 11, 2014 It is hex drive in the front dampers. Look at your picture the hex drive is on the top edge of the adjusting hole. Thanks I did think this Mark, but the tool they give is too small. You saying I could just use another hex tool and turn it the same as you do with the rears? Share this post Link to post Share on other sites
