stephen
Main beam feed for auxiliary lights
trying to hook up a couple of driving lamps ("spot lights"). Will run feed/earth from battery to a relay to be fitted near to left hand  (nearside) headlamp  -  I have identified the multi plug on the lights (8 way) but unsure which is the main beam. I would guess at the blue one (or red on the right hand multi plug) - is this the right one? Anybody else fitted additional driving lamps?
I am using   http://www.amazon.co.uk/Ring-Automotive-BRL0542C-Microline-Rectangular/dp/B00BEI7898
I've never seen a GT/BRZ with driving lamps on it. The standard headlamps are pretty good. Where are you going to mount them?
I'm guessing somewhere in front of the grill?
suspended from the bottom of the number plate box. I would have preferred to mount in the blank bits of the bumper each side of the numberplate box, but it's solid. I do a lot of night driving, and much of it on the continent, so feel the need for more light on the subject!
