BRZ-123
  • Days Won
    33
Everything posted by BRZ-123
  1. BRZ-123
    Batteries and alarms
    Like this today, now that you reminded. A multimeter said the Voltage was 12.2V , so about 50% charge left. Sent from my SM-G781B using Tapatalk
  2. BRZ-123
    My car never did it before lockdown as it was a daily being used 6 days / week , 50 miles a day. Its also parked on the drive, far from a plug socket. So my approach is get the extension roll that I use for the lawnmower, see a good day and connect the Ctek. Battery charges in 6 hrs and in goes the ctek and extension. Important to buy the 7.5 or 10A one not 5A as that takes 12 hrs to charge fully. What I meant by a permanent connector was this which you can leave on your battery. Makes connecting and disconnecting a doddle. https://www.ctek.com/uk/products/car/connect-eyelet-m6 Sent from my SM-G781B using Tapatalk
  3. BRZ-123
    Might be worth investing in a CTEK charger and keep the connectors on. Use it to charge the battery every few weeks. Buy a 7.5A one not 5A as that takes 12 hrs to charge, so too slow in my opinion. Sent from my SM-G781B using Tapatalk
  4. BRZ-123
    MartinT's BRZ
    From Amber perf https://www.amber-performance.co.uk/product.php?xProd=25509 MAIN BENEFITS - Ensures the clutch engagement feeling is the same as the standard clutch. - Up to a 30% increase in torque capacity over standard. - Approximately 40% higher clamp load than the standard clutch. - Industry leading performance friction, achieving the highest fade recovery, the highest RPM burst test results, the best heat resistance and the lowest wear rate in the performance after-market.* Sent from my SM-G781B using Tapatalk
  5. BRZ-123
    MartinT's BRZ
    https://www.gt86.org.uk/forums/forums/topic/7345-clutch-for-fi-car/?tab=comments#comment-114727 Xtreme and Exedy both seem to review well. Check the torque specs Martin. Exedy stage 1 is rated at 190 lbft at flywheel, 160 at wheels supposedly. Your car produces more torque than that , I believe. What are the telltale signs of a slipping clutch and how much is the replacement going to cost all in Martin? Sent from my SM-G781B using Tapatalk
  6. BRZ-123
    Rusty Sump
    Not mandated by Toyota. Question back to you , does the Toyota come with a 12 yr paintwork anti perforation warranty? If yes, then it would be a condition to get it inspected every year at service and get a reseal done at Yr 6. Logically they are the same car made in the same factory by Subaru, so if the car is a keeper for you , then I will get it done irrespective of what Toyota mandates ( or not). Sent from my SM-G970F using Tapatalk
  7. BRZ-123
    Rusty Sump
    I assume then the first owner did not give you the bodywork guarantee paperwork then? It does not seem mandated by Toyota. If you live close to Sussex , you can use Protectorust to do a professional thorough job for £200 with Waxoyl or Dinitrol. If you don't mind, how much is the Sump costing? You will need to leave the car overnight at the garage for the sealant to dry. How is your LSD sump/ housing looking? That bit needs some TLC in my car which I plan to do this summer. Glad it's not all the new baby getting the attention and the baby from the land of rising sun still gets tlc. Sent from my SM-G970F using Tapatalk
  8. BRZ-123
    Rusty Sump
    Here you go, from the Subaru manual for a BRZ owner Sent from my SM-G970F using Tapatalk
  9. BRZ-123
    Rusty Sump
    Interesting to note. The car is meant to be rust proofed at 6 yrs / 60K. Did you get that done? That should've sorted the subframe. Don't think they spray waxoyl on sump and the manifold heat cycles must be bubbling off the paint. What sump are you going with? IIRC, Cusco has a baffled, finned aluminium sump with potentially better oil cooling. Sent from my SM-G970F using Tapatalk
  10. BRZ-123
    Fitting header + ecutek
    I am in RG6 I can let you borrow my ECUTEK if you are ready to spend the £85 ans we come out of lockdown. I am still not sure how you will save money on it as you will need the license + you will need to buy a remote tune from Fensport or Abbey . It's neither easy nor quick to tune yourself but less than 5 mins to upload a tune file and then a few mins to datalog and send the tune for fine tuning. Sent from my SM-G970F using Tapatalk
  11. BRZ-123
    Lowered springs GT86
    The closest to you will be Fensport. Speak to them about the options available. Sent from my SM-G970F using Tapatalk
  12. BRZ-123
    Fensport vs Tuning Developments
    Rather than paying them for a dragparison, just pay for a FI kit and enjoy the boost. or you book a few of us with various kits at santapod and we will do it for you live
  13. BRZ-123
    It was tested on CARB California exhaust rules, so stock exhaust and both Cats intact . I think with that set up a Harrop would be ballpark thereabouts Martin. Dont you think so? Sent from my SM-G970F using Tapatalk
  14. BRZ-123
    Took me a while to find it ,this is the best review for FI kits with all sorts of data and slants just from across the Atlantic. Take your time and read it a few times over Jay. Edelbrock is very similar to Harrop as it uses the same charger Eaton TVS 1320. So reference it that way and enjoy making your mind up. https://dsportmag.com/the-tech/showcase/the-2018-86-challenge-presented-by-eneos/2/ Sent from my SM-G970F using Tapatalk
  15. BRZ-123
    I did tell them which is why they did not bother fitting that turbo engine to the BRZ in first or second gen even though they had to develop the NA variant specifically. [emoji6][emoji6]For a high ground clearance SUV or even a rally car vs a low to the ground sports car, no comparison mate. [emoji3] Sent from my SM-G970F using Tapatalk
  16. BRZ-123
    Very few will claim they did damage driving their car through water. That's an idiot claiming he is one. [emoji2960][emoji3] So forums will not abound with such feedback. I did say its not a hugely likely scenario but with a low car and potentially lowered , is not a brilliant design for a daily. Great for track though as low COG. Sent from my SM-G970F using Tapatalk
  17. BRZ-123
    Fair shout. Intake on one side ( not the sucking of water into engine and total write off scenario) , turbo itself runs so hot that any water touching it will cause it to split/ crack and is not a cheap replacement. So the risk exists with low cars like ours and while the design has pros of low cog and potentially lower intake temps , it has cons as well. Sent from my SM-G970F using Tapatalk
  18. BRZ-123
    If its a daily, a low mounted turbo on a low car runs a potential risk of water ingress , especially with deep puddles. Does not happen frequently but is a risk due to design. Sent from my SM-G970F using Tapatalk
  19. BRZ-123
    As you are talking about exhausts and as others have mentioned, a turbo will come with its own manifold (nearly always catless) and a second decat is recommended as the cats get damaged with the flow, which makes most turbos not Road legal [emoji848]. Friendly MOT mechanic is the only suggested way which i principally disagree to. SC works on intake side not exhaust , so with your gains of 230 WHP and not chasing silly figures, a fully OE exhaust will work easily keeping it road legal and MOT friendly. Sent from my SM-G970F using Tapatalk
  20. BRZ-123
    You need to use the search functionality and read some threads and debates about SC vs TC etc and the dealers. All 3 of them are reputable in this community. TD do their own kit, the rest install kits from AVO etc. So choose based on convenience and preference than comparing one against the other. Superchargers are of 2 types , centrifugal ( HKS kit) which is more like a turbo and positive displacement ( Harrop , Cosworth). PD delivers torque from low down while all our turbo applications only deliver power beyond 3K RPM. So what application do you want it for - City/ Town driving or track days? All kits are generally reliable until you go overboard with tuning or forget additional oil cooling etc if you hit tracks regularly. PS: Spend a lot of time searching this forum reading up build threads and dyno graphs and any blown engine cases etc , where you will also know why. Sent from my SM-G970F using Tapatalk
  21. BRZ-123
    How do we report a user
    Seems to be working now. At the minute on the tapatalk app a moderate button has activated. I'll log into my PC later to check if there is something else that does not show on app. Sent from my SM-G970F using Tapatalk
  22. BRZ-123
    I've blocked him Gavin. So he has a further terrible winter and does not get help [emoji848] Sent from my SM-G970F using Tapatalk
  23. BRZ-123
    I am also happy to support part time as a mod. Lauren , do not leave our forum and go to the GR Yaris one. :-) Sent from my SM-G970F using Tapatalk
  24. BRZ-123
    Stubaru BRZ
    Hearty congratulations, from an NA flat 4 to an NA flat 6, this is the upgrade.[emoji846] From 4 seats to 2 is the downgrade [emoji6] from £10-15K , used to £25-50K used is a big upgrade [emoji2960] Enjoy the new toy. Sent from my SM-G970F using Tapatalk
  25. BRZ-123
    GR Yaris and Civic Type-R (FK8)
    Very interesting and two clean white cars for the pictures. Bliss. If you add a Turbo'd or Supercharged GT86 to the mix to compare, it will be even more fun. FWD , VS RWD vs AWD, all forced induction. If you have a friend with a Yaris GRMN again a great shootout against yours, turbo vs SC FWD vs AWD Sent from my SM-G970F using Tapatalk
