Lucas 244 Report post Posted April 17, 2019 Special revised price - £1945 inc. VAT The Cosworth AP Racing brake kit delivers not only looks fantastic but it delivers ultimate stopping power consistently and quickly from cold whilst offering corner weight reduction over the OEM brakes of 1.58Kg. The Cosworth BBK calipers are 6 piston, with differential bores to eliminate "pad taper". All our performance brake calipers use conventional seals in conjunction with a dirt seal and are finished with an eye-catching high gloss black PTFE based paint coating which is impervious to normal brake fluids & high brake temperatures. The 2-piece discs features Cosworth technology embedded within the pair of 48 vaned discs together with lightweight high grade aluminium mounting bells designed to deliver enhanced airflow than the original brakes. The discs have been developed to produce optimum braking bite, as well as thermal stability and durability. Cosworth Big Brake Upgrade Kits are a stylish and effective way of up-rating your cars braking performance. Detailed Specification: 2 x Ø355 x 32mm 2 piece brake discs 2 x 6 piston brake calipers High performance brake pad friction material* Braided brake hoses 2 x Dot 5.1 high temperature brake fluid 2 x Mounting brackets 2 x Aluminium mounting bells Steel braided hoses Fixings These discs are drilled in both 5x100 and 5x114.3 pcd.Be careful, these are 355mm discs and will require larger wheels. If you're uncertain whether these will fit into your wheels, please contact us before buying. We can supply a template for you to test inside your wheel. Share this post Link to post Share on other sites
