Lucas
Get a Grip! KAAZ Limited Slip Differentials
Hi everyone, KAAZ L.S.D.'s will go up in price by about 5% as of 1/10/18, so if you want to improve your track times or start drifting properly, this might be something to consider.
I can give you a general 10% Forum discount to use on www.part-box.com and if you purchase it by the end of the month, you're saving 15% which is a decent chunk on high value products like Differentials.
I definitely recommend KAAZ 1.5 Way SUPER Q diff for daily / track cars. You can go for the standard non-super Q version. It's cheaper, but also slightly more aggressive and noisy, so it can be mildly annoying if your car is daily driven.
2 Way differentials are used for Drifting as they feature a consistent 100% Lock on Acceleration and deceleration. Again Super-Q would be more suited for Daily driven drift cars as it doesn't engage so aggressively. 2 Way diffs are by no means like welded differentials, so don't associate 2W LSDs with welded diffs, you will not get any wheel hop while trying to parallel park like you would with welded diff, so don't be scared of it if you drift more than track it.
KAAZ 1.5 Way Limited Slip Differential - Toyota GT86 / Subaru BRZ - £678.36
KAAZ 1.5 Way Super Q Limited Slip Differential - Toyota GT86 / Subaru BRZ - £767.23
KAAZ 2 Way Limited Slip Differential - Toyota GT86 / Subaru BRZ - £678.36
KAAZ 2 Way Super Q Limited Slip Differential - Toyota GT86 / Subaru BRZ - £767.23
All KAAZ L.S.D.'s are supplied with KAAZ L.S.D. Gear Oil
