benmmellor
Mirror auto close module issue?
I've fitted one of the Subaru BRZ auto mirror close looms which does the job when locking the car.
The last few mornings when I've started the car the mirrors have stayed folded in rather than fold out. Checked the mirror fold button and that's as should be.
If I press the button in and out and the mirrors pop out.
Later when I park up and return to the car the mirrors have unfolded as expected when I start the car.
Seems a little odd to behave like that now after installing the module ages ago.
Any ideas folks?
Sounds like loose connection to me. I don't know whether the module is in parallel to the button or in series but it could be just a cable not making good connection somewhere from all the potholes on the road :D
well after behaving most of last week, they seem to be playing up again today. Swapped the fuse as an possible fix - doesn't seem to work. Might have to take the door card off and recheck the loom fixings - but as they are locking tabs on the connectors I'd be wary of it being this.
Will take the loom off and see if they behave - hopefully it won't rain today/tomorrow when I get chance to do it.
seems to be switch related as the mirror adjustment won't work at all either.
hmm - oddity issue as all the connections were still tight to the switch module and connected securely. Unplugged the BRZ mirror loom black box (8 pin connection) and re-attached. Seems to be working now.
Must have been in need of standard IT 'percussive maintenance & wiggle' technique!
