DanJ 374 Report post Posted March 23, 2016 Does anyone happen to have stock Front and Rear anti-roll bars that are off their car? If you do I'd be very grateful of some measurements, I'm setting up a suspension calculation spreadsheet to work out roll stiffness distribution between the front and rear axles on the stock car and then use this to compare to changes in spring rates and ARB rates for possible mods. I'll happily share this spreadsheet for anyone else to use once its all done. Thanks, Dan. Share this post Link to post Share on other sites
Tareim 343 Report post Posted March 23, 2016 IIRC it's front 16mm / rear 14mm Share this post Link to post Share on other sites
DanJ 374 Report post Posted March 23, 2016 Yep that's right, but I need some other dims as well to work out the effective stiffness at the wheel. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 23, 2016 I have them off my car. Could get you some measurements tomorrow if you let me know what you want? Share this post Link to post Share on other sites
Tareim 343 Report post Posted March 23, 2016 ah ok, might be worth stating what other measurements you need so people can go out and check then reply when they've got them Share this post Link to post Share on other sites
DanJ 374 Report post Posted March 23, 2016 I have them off my car. Could get you some measurements tomorrow if you let me know what you want? Thanks, other than the bar diameters I need all the other dims shown in this file please: https://www.dropbox.com/s/t2a8jk3cmx4d5sr/sway_bar_effective_spring_rate_calculations.pdf?dl=0 Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 25, 2016 I had a look for the measurements. Sadly I only had a tape measure to use to get these measurements and the shape of the arb's mean it was quite difficult to get them perfectly. For the rear arb I measured a length of 91cm, thickness of 2cm and the arms splay out diagonally and I measured those as 19cm. For the front arb I measured a length of 101cm, thickness of 1.6cm and the arms splay in diagonally and I measured these as 14cm. Hope that helps but if there is anything else just let me know. Share this post Link to post Share on other sites
DanJ 374 Report post Posted March 25, 2016 Thanks Jeff, much appreciated. I think you've got the front and rear mixed up, the rest makes sense from pictures if switched. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 25, 2016 9 minutes ago, DanJ said: Thanks Jeff, much appreciated. I think you've got the front and rear mixed up, the rest makes sense from pictures if Yeah sorry! Wrote the measurements under the wrong headings. Share this post Link to post Share on other sites
DanJ 374 Report post Posted March 25, 2016 No problem, easy mistake to make. Share this post Link to post Share on other sites
