Bollox
About Bollox
    Sweden
  1. Bollox
    Clutch bite position
    Anyone else than me think the height where the clutch bites is a bit too high, leading to not so smooth shifts? I googled it and found this thread http://www.ft86club.com/forums/showthread.php?t=8040 Took me about 3 minutes to make the adjustment, and after 2-3 different tries, I think I am satisfied... It's well easy to do.
  2. Bollox
    Winter tyres
    Nokian make the best - win the annual winter tyre test every year up here in Sweden
  3. Bollox
    How to change your binnacle
    Which colour is this, Charcoal or black?
  4. Bollox
    Center exhaust bolts worked loose
    I had work done on mine the other day - both bolts were missing! only 8000 km on the clock.
  5. Bollox
    Engine and cabin heater fitted - for free
    I would say that anyone living north of my old hunting grounds in North Yorkshire would benefit from the lower fuel consumption and the reduced engine wear - at least if they keep the car for a couple of years.
  6. Bollox
    Firstly, yes I mean core plugs- been here too long so I literally translated "frysdisk/freeze plug" We have of course a heater in the car, but in the winter, the temp here (same latitude as Stockholm) is nearly always at -5C, and can easily get to -20C. In the North, I have experienced -40C! So, when your car has been standing overnight, the engine block is well cold, and all the windows are iced up, sometimes even on the inside (as there will be melted snow from peoples shoes). So, in our yard is a post with 240V and a timer. I connect my Calix engine block/cabin heater cable to the timer, set it for 2 hours before I drive to work, and go to bed. When I go to my car in the morning, the windows are ice free, the cabin is warm, and the coolant, if not at running temp, will be after 2 minutes of driving Important tip is to remember to disconnect the cable before driving off I find a post-it on the steering wheel does the trick. At many work places you can hire a 240V/timer post, so you can repeat the procedure on the way home. Diesel cars use a small burner driven by the car's diesel, so you don't even need 240v - the timer is built into the car, and often you can use an app to set it from your smart phone. Here endeth the lesson Cheers / Alec
  7. Just got my car back from Calix here in my home town in Sweden. They make heaters for cars etc. For those who don't know - basicaly a heater coil is plugged into the block where one of the freeze discs go. This is connected to an external socket, which also feeds an outlet in the cabin, where a small (removeable) electric heater fan can be connected http://www.calix.se/en/products/engine-heaters They needed a car so they could test fit and document the fitting, so they borrowed my car for 2 days, and I got a loaner PLUS the €300 kit for free Means I can plug the car into a timer socket outside my house when frost is expected, and wake up to a warm car, with the coolant already heated up = less pollution, less wear on the engine and more MPG. Here's a pic of the cabin heater and the external electric socket. Bit of a boring mod, but well worth it if you live where it gets cold.
  8. Bollox
    Ex-pat from Sweden
    Hi to all, I´m an ex-pat living in Sweden the last 20 years. No real big GT86 forum over here, though there are 3 other cars in my town. I just bought a ginger GT86 with 8000kms on the clock yesterday. It's at the shop today, getting an engine/cabin heater fitted . I loan them may car, they do the install and create all the fitting instructions for others to use - I get to keep the finished installation :-) One thing they did notice was 2 non-existent exhaust mounting bolts, so that was a bonus. Seem to be plenty of good tips here, so I'll be back with my wish list later. Regards, Alec PS Yes that is my number plate in my Avatar :-D
