MattR
About MattR
In case anyone has this problem in the future, my system has been fixed. It turned out to be one of the compressors and also the daylight sensor (which strangely effects the aircon). My main take away from it is DO NOT GO TO TOYOTA (Bromsgrove) they diagnosed it as a leak in one of the high pressure pipes even though the system was not losing pressure, which either tells me that they didn't pay much attention when doing it, or didn't understand how to fix it - I'm not sure which is worse. Always get a second opinion, if you live around the West Midlands area then Fitch Auto's have been fantastic.
It isn’t no, or at least I hope not! Mine has been in to a garage called Fitch Auto’s in Walsall. You’ve seen some other unfortunate soul to be having aircon issues!
Hi All, Dont appear to be having much luck at the moment with the GT86 - currently in the middle of having an aircon issue diagnosed and now getting a high pitched whistle noise. I have looked it up and I’m aware of the chirping noise borne from an issue with the fuel pump, however this is less of a chirp and much more constant and high pitch - no other video I’ve found has sounded quite as bad. It’s definitely high pressure.
I believe it probably is a set, they said something about it including the seals too. Ok thanks I’ll have a look!
I believe they probably gave me their own internal part # as I haven’t been able to find it either - even a garage with access to a Toyota parts list database couldn’t find it - I guess it just references back to a Subaru part any way.
Hey, yeah I’ve already found a garage over in Walsall that will do the 1234yf for £110 so I’m not worried in that regard. At the moment I’m worried about trying to source the part.
Hi all, Recently bought my 86’ and noticed that the aircon is busted. Toyota have diagnosed it as being a damaged pipe from the Condenser to the Evaporator (and quoted £700 to fix it ofcourse) so I’m going to just buy the part myself and get a local garage that has the gas and will do it for a reasonable price to sort it. However, I’m having trouble finding the right part for it. Does anyone know which of these parts is the one I’m looking for? https://www.subaruparts.com/auto-parts/2015/subaru/brz/limited-trim/2-0l-h4-gas-engine/hvac-cat/condenser-compressor-and-lines-scat The garage also gave me the part number (TSU 003-A0010) but haven’t been able to find reference to that anywhere else. Any help would be greatly appreciated. Thanks!
