Lundster 1 Report post Posted August 23, 2017 Hey guys, I'm going to be renewing my front ksport rotors and brake pads with ksport rotors and ebc red stuff pads. Current setup: Ksport grooved 330mm rotors Ksport 330mm 8 pot calipers (yellow) Ksport brake pads Front wheels are work emotion cr kiwami 18" I have no idea what the torques are and not sure what kind of rewind tool I'll be needing. Anyone out there that has the same brake kit and happens to know the torques and rewind tool required? If this is the wrong section then I'll move it. Cheers for any help Share this post Link to post Share on other sites
thetyrant 30 Report post Posted August 23, 2017 No piston rewind tool required just a spreader or old pad to lever pistons back. Bolt torque see install instruction pdf here - http://ksportusa.com/edocs/bbk_manual.pdf 1 Lundster reacted to this Share this post Link to post Share on other sites
Lundster 1 Report post Posted August 23, 2017 Thanks! Share this post Link to post Share on other sites
