Introduction:
Hello everyone, I've decided it's about time I did a proper build thread for my 2nd Subaru BRZ as thing are now starting to get more interesting.
My plan is to build a fast road car with some track focused additions. The car is my daily vehicle so I'm not planning to strip it out and turn it into a track monster. Just something that is easily to live with during the week but gets thrashed at the weekend.
Thanks for looking
Will
Here is my current list of modifications:
Engine and Exhaust:
ACE Header - CS400 Manifold – Ceramic Coated by Performance 1 Coatings in Volcanic Black
Rogue Motorsport 2.5" Front pipe with CAT and Resonator
Rogue Motorsport 2.5" Resonated Catback exhaust
Hel 19 Row Oil Cooler
SPA Design - Oil Temp & Oil Pressure Gauge (Block8Head guage holder)
Cosworth Sump baffle
Cusco Sump plug
Perrin 3” Big MAF Cold Air Intake
Tuning Developements Ecutek remap
HEL Performance braided clutch line
STi Engine Mounts
Previously Installed:
AVO 2.5 Non-Resonated Cat Back Exhaust (Previous)
Tomei Type 80 Titanium 3” Exhaust (Previous)
Stock 2nd CAT (Previous)
Cosworth Low Temp Thermostat (Removed - Standard item refitted)
Suspension, Chassis & Brakes:
Tein Flex A Coilovers – Approx 35mm drop
Summit Rear Control Arms
Whiteline Anti-Roll bar kit - BSK016 (F: 20mm - R: 16mm)
Whiteline Front Roll Centre / Bump Steer Correction Kit
Custom AP Racing Big Brake kit by Reyland Motorsport - AP Racing CP9200 Calipers, AP Racing 330x28mm discs
Subaru WRX STi Rear Brembo with DBA Rear Brake Disc - DBA42656-10
PFC 08 Front Brake Pads
Endless MX72 Rear Brake Pads
Hose Technic Braided Brake lines
Cusco strut tower bar with master cylinder brace
Perrin shifter bush
Powerflex rear diff mount Left & Right bushes
Powerflex front and rear subframe inserts
MTEC Shift Springs
MTEC Clutch Spring
3" Shift Extension from Ebay
STi Steering rack bolt upgraded
Cusco Steering rack bush
Cusco Steering rack brace
Cusco Brake pedal support
Wheels and tires:
Current Setup:
Wheels: Rays Gramlights 57CR 17x9 +38 in Gold
Tyres: Michlin Pilot Spot 4 in size: 245/40/17
Spare:
Wheels:949Racing Wheels 17x8 +40 in Black
Tyres: Yokohama Advan AD08RS in size: 225/45/17
Winter Setup: n/a
Previous Setup's:
Wheels: Japan Racing JR29's 17x8 +35 in Bronze
Tyres: Michelin Pilot Sports 4 in size: 225/45/17
Wheels: Rota Grid Drifts 17x9 +42 in White
Tyres: ContiSport Contact5's in size: 245/40/17
Wheels: Japan Racing JR18 17x8 +35 in Custom Bronze colour
Tyres: Goodyear Winter Tyres in size: 215/45/17
Exterior:
Tinted rear window & rear side windows
Debadged
Rear Spoiler Delete
Voltex Type 1S - 1480mm wing
TRD Fender Fin in D4S Black
Rays Dura-Nuts L42 Blue wheel nuts
Verus Engineering Race Splitter with end plates
Verus Engineering Non-Aggressive Diffuser
Verus Engineering Mustang GT-550 Bonnet Vents
Subaru STi Side Skirts and Rear spats
Valenti Revo Smoked Rear Lights
Valenti bumper / reverse light
Valenti front bumper side marker lights
OEM 17+ Shark Fin in D4S Black
Rogue Motorsports windscreen banner
Previous:
Genuine SARD LSR GT Wing (Previous)
White side stripes (Previous)
Interior:
Alpine INE-W925R Head unit with Navigation
Cobra Nogaro bucket seat with custom Rogue Motorsport Seat mounts (using OEM sliders)
Perrin Cam Solenoid covers
Schroth Rallye 3 ASM Harness
Top Sage Bonnet Struts
Possible Future Modifications:
See: https://www.gt86.org.uk/forums/forums/topic/4097-will300s-subaru-brz-build/?do=findComment&comment=115677
Pictures:
Current:
Previous:
Dyno Plot - Current:
ACE Header / AVO Exhaust / Cosworth Panel Filter / Fensport Remap - Green
ACE Header / AVO Exhaust / Perrin 3" Big MAF Cold Air Intake / TD Dyno Remap - Red
Dyno Plot - Previous:
Stock Car / Cosworth Panel Filter - Green
ACE Header / AVO Exhaust / Cosworth Panel Filter / Fensport Remap - Purple
Over the last few weekends I decide to start a new project on the BRZ, sound deadening. Recently during the last 6 months I've started to get feed up of the amount of road noise that gets feed into the cabin. So in an attempt to tackle this I did some research on the various 86 forums and came across the following guide: http://www.ft86club.com/forums/showthread.php?t=53511.
Using that guide as a base I bought some sound deadening materials from Amazon and went about installing it all.
Materials used:
Silent Coat tiles - https://www.amazon.co.uk/Silent-Coat-187x265mm-Deadening-Proofing/dp/B00NVE013I/
Dodo Pro Barrier MLV - https://www.amazon.co.uk/Dodo-Mat-Barrier-Proofing-Camper/dp/B00LUOQWDY/
Silent Coat absorber foam: https://www.amazon.co.uk/Silent-Coat-Sound-Absorber-Proofing/dp/B00CV0BM0O/
Sound deadening insulation
Over the next couple of posts will be various pictures of the install. I decided to start with one of the most difficult jobs of the lot, the roof. Followed by the rear wheel arches.
Roof Install - Headlining removed
Silent Coat tiles added
Additional sound deadening insulation material
Head lining re-installed.
Rear Wheel Arches:
Silent Coat tiles applied
Sound deadening insulation material filling the remaining gap
Dodomat Pro MLV added to rear quarter panels
This has definitely helped as it moved the noise from the back of the cabin more towards the front, it's still to noisy though, on the next step.
