BRZ-123 174 Report post Posted March 17, 2022 Hi All, Sooner or later, my car will need a new clutch and i am exploring the options. I want to ideally upgrade it but with OE quality. With this in mind, would someone be able to confirm: 1. The GR86 clutch specs ( torque,power limit) and part number in the UK? 2. The UK toyota Part Numbers? 3. If they will be backwards compatible with the Gen 1? Thanks in advance Share this post Link to post Share on other sites
will300 812 Report post Posted March 17, 2022 This might help: https://parts.toyotasm.com/p/Toyota_2022_GR-86/DISC-ASSEMBLY---CLUTCH/105791511/SU00308588.html 1 BRZ-123 reacted to this Share this post Link to post Share on other sites
BRZ-123 174 Report post Posted March 18, 2022 On 3/17/2022 at 12:27 PM, will300 said: This might help: https://parts.toyotasm.com/p/Toyota_2022_GR-86/DISC-ASSEMBLY---CLUTCH/105791511/SU00308588.html Thanks Will. Very helpful and gives the part numbers. Struggling to get any tech specs to know if they are really upgraded or not. Share this post Link to post Share on other sites
Feemono 7 Report post Posted April 9, 2022 On 3/17/2022 at 12:27 PM, will300 said: This might help: https://parts.toyotasm.com/p/Toyota_2022_GR-86/DISC-ASSEMBLY---CLUTCH/105791511/SU00308588.html My my, are these legit order-able ? I was just looking at the prop shaft for the GR86 which I gather is lightened over the GT86. And I see some synchromesh bits also. I wonder just how much of the GR86 we can buy!! Probably work out in Toyota's favour seeing as they're stalling so much in getting the actual GR86 here. Share this post Link to post Share on other sites
MartinT 514 Report post Posted April 11, 2022 If you want an OE like clutch able to take the torque from a supercharger, I can recommend the Exedy Stage 1. It feels exactly like OEM. Sent from my Oppo X3 using Tapatalk 1 BRZ-123 reacted to this Share this post Link to post Share on other sites
