AnInnocentGT86
Technical issues with a used turbo kit
Does anyone know the problems that might come with installing a used turbo kit? Assuming the turbo kit is in a good condition.
I was going to look for a used turbo kit but I guess I have to figure out the technical issues first, then start looking into it.
What do you mean by technical issues? Do you mean missing parts? or actual turbo issues i.e. boost leaks, oil leaks, etc.
Also used turbo kits come up very rarely and a different turbo kit might have a different requirements to setup etc.
I guess knowing that all the supporting bits that were initially part of the kit are included. One of the main ones that comes to mind is the oil cooler.
Either way if you get a turbo kit you're going to need it mapped afterwards but hopefully you already know that. 😁
