Billy THE Kidd 0 Report post Posted March 24, 2021 Hello all, and apologies upfront as I would imagine this question has been asked many times already, however, I have spent nearly 1-hour searching through posts to no avail. I have a UK spec 2015 GT86 and am looking to fit new brake discs and pads all around but, I'm having trouble establishing whether the rear discs I purchase should be vented or solid. The currently fitted discs are solid but I believe they are cheap after markets and may not be correct. hence my query. AFAIK the standard UK spec replacements should be as follows (including fronts): FRONT: Ø294mm vented REAR: Ø290mm ??? FYI, I am looking at MTEC and they seem to be offering non-UK spec size discs in both vented and solid but at different diameters so the confusion continues. I'm not looking to upgrade my system (calipers) or anything like that, I just want to make sure I buy the right discs for the rear and the question is, vented or solid as the thickness will obviously be a factor with the standard calipers. Cheers people for any support you can provide in clearing up this query for me. Share this post Link to post Share on other sites
Leeky 84 Report post Posted March 24, 2021 100% Vented. I cant say I’ve ever seen an 86 with solid rear discs. Maybe they are from the Primo models that came with smaller brakes? 1 Kaltorak reacted to this Share this post Link to post Share on other sites
Shad 20 Report post Posted March 25, 2021 Definitely vented. Just bought a set of these for mine: https://www.ebay.co.uk/itm/Brembo-Rear-Axle-Brake-Disc-Set-Subaru-BRZ-09-C662-11-/283705843947 Share this post Link to post Share on other sites
Billy THE Kidd 0 Report post Posted March 26, 2021 Many thanks chaps, I'll order vented then. Share this post Link to post Share on other sites
