Winterhalder 10 Report post Posted February 20, 2021 Hey all, So I am returning to the thought of getting a GPS tracker fitted. I bought an inexpensive Chinese tracker a while ago, SIM card requirement with SMS alerts - which is hard wired and never figured out how to fit all the wires and locate the tracker and GPS transmitter. Then I looked at ReWire and iTrack which have an easy connection to the main battery, but figured it's obvious and easy to remove upon opening the bonnet - they also do hard wire, but I'm back to getting it fitted properly (they charge £100+). Both companies have subscriptions at £5+ per month for the app and detailed tracking. But I would be happy with something functional (alerts based on movement and GEO fencing) I don't need remote immobilisation and all the app features. I'm also not doing this for insurance purposes, which should be obvious. So I think what I'm asking for is any recommendations for someone or a garage to hard wire fit a GPS tracker in Essex!? Or, clear instructions from someone who has done it on a GT86. As always, thanks... Phil. Share this post Link to post Share on other sites
Church 209 Report post Posted February 20, 2021 Hearing how often guys in UK have problems with battery going flat (probably due alarm systems UK twins are fitted normally with), and even more so now, in lockdown/relatively little driving times, i'm not sure i'd wish to add another current user extra draining battery 😕 2 surrey86 and Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
NJay 10 Report post Posted February 22, 2021 They have a battery that lasts a few weeks as it goes into a deep sleep mode after detecting it's not being charged and no movement. It charges when the ignition is on so isn't a drain on the battery. It wakes up and sends out location via sms at your predetermined intervals once movement is detected or ignition is turned on. The version I have is the size of a matchbox and has a magnetic base which has held it exactly in place. Doesn't need line of sight either so easy to covertly install. Share this post Link to post Share on other sites
