Lucas
Cusco Front Strut Bar with Brake Cylinder Stopper
You can never have too much chassis stiffness. Weight aside, the more the better. Chassis bracing maintains alignment angles and spring rates by greatly reducing body or chassis flex. In fact, it helps every component in the suspension system do its job properly and you can feel the difference through improved turn-in, sharper steering response along with greater steering feedback. Because this strut bar comes with the brake cylinder stopper, it also greatly reduced the firewall flex under heavy braking, so provides more precise feel for the brakes.
This is now on clearance.
We have 3 of them in stock.
Price is £203.82 £165.09
