Leeky 84 Report post Posted June 4, 2020 Hi All, I’ve been tinkering with my Scangauge to show my Oil Temp and Auto Gearbox Temp. Most codes you’ll find online are for the FRS so they are in DegF instead of DegC, but i’ve managed to get a load of useful gauge codes and thought I’d share. I’dd add more useful codes as I find them. Engine Oil Temp Deg C - TXD- 07E02101 RXF- 010702E80324 RXD- 3008 MTH- 00010001FFD8 Engine Oil Temp Deg F - TXD- 07E02101 RXF- 010702E80324 RXD- 3008 MTH- 00090005FFD8 Automatic Gearbox Fluid Temp Deg C - TXD- 07E12182 RXF- 046105820000 RXD- 2802 MTH- 00010001FFD8 Automatic Gearbox Fluid Temp Deg F - TXD- 07E02182 RXF- 046105820000 RXD- 3808 MTH- 00090005FFD8 Air/Fuel Ratio - TXD- 07DF0134 RXF- 044145340000 RXD- 2808 MTH- 05B900800000 1 James7 reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted June 4, 2020 I have a facelift BRZ so engine oil temp is in the dash. I also have a manual gearbox. The AFR is a standard selectable display, I didn't need a code for mine. Also IAt is a useful one. And MAP as I had a 3-bar MAP sensor installed for boost. 100 is atmospheric air pressure. Share this post Link to post Share on other sites
Leeky 84 Report post Posted December 13, 2021 Looks like there is a way to Swap the MAP value for a BST value and then is displays the pressure in PSI. https://www.facebook.com/watch/?v=556572085128134 Share this post Link to post Share on other sites
MartinT 514 Report post Posted December 13, 2021 I prefer BAR, thanks Sent from my Oppo X3 using Tapatalk Share this post Link to post Share on other sites
