andrewbaru
Hi all
Just a quick note to say hello and a few things I've done/intending on doing which may be of interest:
  • Add a centre arm rest (these are REALLY worth having) - done
  • A lot of research on 2017+ head unit wiring, much of the diagrams out there are only 80% right as they reference generic subaru/toyota wiring or <2017 models - done
  • Hard wire installed a front/rear dashcam (without cutting/splicing OEM wires) - done
  • Replace factory clarion head unit with steering wheel controls retained - done
  • Add a dab aerial that isn't rubbish and/or sticks on your windscreen - done
  • Install reverse camera (without drilling the boot handle or cutting/splicing OEM wires) - done
  • Maybe, possibly, maybe see if I can source and install the mysterious/elusive (H2717CA000) auto wing mirror fold mod - to do
Which head unit did you go for? I ended up with an Eonon and have retained the steering wheel controls and USB socket. Quite a puzzle to get the right adapters and programme the steering wheel learning, though.
I went for a sony unit with android auto/weblink/car play (it also has steering wheel key learning)
And yes, the harnesses can be a conundrum, but basically you need this:
https://connects2.co.uk/Product/ProductItem/CTSSU004.2
but especially retaining the usb, as it "kinda depends" which adaptor you need, on most cars/oem head units you need this one...
https://axxessinterfaces.com/product/AX-SUBUSB
however, mine needed this one...
https://axxessinterfaces.com/product/AX-SUBUSB2
which (at the time I bought it anyway) I could ONLY get from america. It would be VERY easy to get caught out by this as the little notch on the socket is ever so slightly different. After reading around, I also discovered this...
https://www.tme.eu/en/details/usb.toyota.02/power-car-accessories/per-pic/c8304-usb/
I haven't tested it thoroughly, but apparently, if you have problems with android auto/car play connection, try swapping your USB adapter for a usb.toyota.02, the difference being the first one plugs into the weird OEM usb connector, where as the second one plugs into the back of the head unit (standard usb a) and completely replaces the in dash usb/aux socket
Other quirks....
You may need to "deal" with the blue fm antenna wire, not on mine, it's perma wired in, but in general you need the antenna adapter: https://incartec.co.uk/product/Toyota-09--Aerial-adapter-to-din-plug
You may not have a reverse or parking brake signal to the 28pin block, I did on mine :)
Don't get me started on the reverse camera, that was fun figuring out
