BOBEL 73 Report post Posted January 12, 2021 As the lockdown tennis continues I took full advantage of Black Friday deals before Christmas and decided it was time to address a few items that were always on the list First up was getting a new set of wheels, I’ve been running a set of 18 x 7.5 OZ Ultraleggera for the last number of years and it’s limited me to 225 section tyres, and now with the extra grunt traction can be an issue on all but the newest tyres, I’ve got around this by running slicks in the summer but its limiting when you get a spot of rain (as we often do in Ireland) So I opted for a set of Konig Hypergrams 18 x 8.5 et38, and later fitted some Nankang AR-1 255/35 so they should offer a nice bump in traction (the photo below is just the old set of R888R 225s I threw on for test fitting) While I was fitting the new wheels I got distracted and decided to fit a tyre rack to my trailer so I could at least fit some wets to the old wheels and bring them with me Upto this point I’ve kept the external of the car pretty standard looking, but I always intended to fit some functional aero and I’ve always been tempted by the Verus Engineering parts, so I took full advantage of their Black Friday deals and bought this lot! First up was fitting the adjustable front splitter, I opted to install it at 5” extension just too see how it will work, However the install of the front splitter was not straight forward as anything beyond a 3” extension meant that two of the tie rods would extend beyond the bumper, I ended up drilling two new mounting holes further back and making two offset brackets, I also ran into issues with the length of the tie rods, which at 5” were running at max extension with very little thread engagement left within the turnbuckle, so I installed some spacers behind the crash beam brackets to allow me to shorten them a little. I also went with the accompanying end plate and canards, while installing the end plate I decided to reinforce the bumper edges with some aluminum backing plates just to give the rivet nuts a better chance of staying put! Finally all were installed With that lot sorted I’ve still got the rear wing, and bonnet vents to fit. I’ve also bought the Verus steering angle limiting kit, as the wisefab kit has given me some extra lock but on full the tyres are touching the inner wheel arch As my persistent 2nd gear grinding continues I also bought a new set of Verus carbon synchros that I’ll get fitted at some stage, and finally my battery was shot after 4 yrs of trickle charging and trackdays so I replaced it with a new Odyssey PC950 3 Shad, Deacon and AJ124 reacted to this Share this post Link to post Share on other sites
BOBEL 73 Report post Posted January 17, 2021 Managed to get the last two major Verus Pieces wrapped up over the last few days I tackled the bonnet vents first while I waiting on a few parts to arrive for the rear wing install. It’s always a little tense cutting into body panels so I must have checked my dimensions about 5 times before the drill and cutting disc were unleashed. Once I had the holes cut out I taped up on both sides and sprayed all the cut edges just to seal them up and stop any aluminum corrosion taking hold. After all the messing about the vents were finally bolted in, safe to say the front of the car no longer looks stock! With the vents completed I tackled the rear wing install, I knew I was going to have to make some small alterations as I have a full fibreglass ducktail that covers the entire bootlid, and the Verus kit is designed to fit onto a standard bootlid. However funnily enough the Verus wing is designed to work with a ducktail and the profile of the wing should nicely tie in with it. In order to get it to work I need to drill through the various layers of fibreglass and bootlid steel and use some extended aluminium spacers inside the boot with longer stainless steel bolts. The wing then uses a stainless steel backing plate on the inside and aluminium uprights on the outside to ensure there is no flex, which is helped by the fact the uprights are right out on the edge of the bootlid. A jacking nut is also incorporated that you adjust so that it is in contact with the OEM boot hinge stopper to further ensure no flexing. When all was installed it does seem very effective, and ties in nicely with the ducktail like I hoped 4 vanko25, Deacon, BRZ-123 and 1 other reacted to this Share this post Link to post Share on other sites
BOBEL 73 Report post Posted February 20, 2021 The last few weeks have been relatively quiet so I took the opportunity to fit the last Verus piece which was the steering rack limiters, pretty simple job which involves slipping some C-shaped spacers around the rack by sliding the rubber boots on either side back, should hopefully stop my wider front wheel from contacting the chassis on full lock. With that little job only taking a few minutes I turned my attention to something a little more experimental. With time on my hands I took a good look at my oil pressures from recent trackdays, and I wasn’t exactly loving the look of them. My oil pressure sensor is installed on the mains and most people estimate the difference between the front cover where most locate their sensors and the mains is +10psi, but not being one to work on assumptions I’ve decided to install a second oil pressure sensor in place of the OEM oil pressure switch which I’ve ditched as its pretty much useless anyway. I know the FA20 is never going to have the most impressive oil pressure given the OEM spec is 46.6PSI @ 6,700rpm @120 DegC which is only 6.9PSI / 1000rpm whereas an old general rule of thumb is 10psi/1000rpm, but I would like to see some more pressure at the main journals regardless. I’ve already got a Reimax high flow oil pump installed but ultimately I think the real problem with the FA20 is the fact the oil supply is not direct to the main journals, after it leaves the oil filter it splits to feed the left cylinder head before splitting again to feed the mains and right cylinder head so essentially the main bearings, and subsequently rod bearing are down the pecking order. So I set about finding a way to essentially create a priority oil feed to the mains, I’ve seen others attempt this in various ways but I was anxious to combine the best of what I’ve seen with something of my own making and see how it works. What I’ve gone with is an adaptor that I’ve modified to fit the FA20. The adaptor re-orientates the oil filter 90 deg and provides a direct tap into the post filtered oil. The adaptor will allow me to run a bigger diameter and longer oil filters without fear of hitting the underside of the bonnet which should reduce any pressure drop From the tap on the side of the modified adaptor I’ve run an oil line directly over and into the main journals where my existing accusump was plumped in. I’ve had to do a little reworking of the setup but it all fits nicely. With this setup the first route available to the oil is now the main journals, before it heads back into the front cover and into the heads etc. One fear with this setup is that too much oil goes to the bearings and you essentially starve the heads, hence the real reason for the second oil pressure sensor. The sensor is wired to my AIM dash so I can monitor both pressures and set up a math channel to monitor the differential between both. So I guess the next trackday will be the test-bed whenever that turns out to be! Share this post Link to post Share on other sites
BOBEL 73 Report post Posted September 20, 2022 It’s been a while since I’ve update this thread, and that’s mostly as the car has been running without fault, the only issue that’s been niggling for the last while is a crunchy shift on 2nd gear, something that becomes audibly worse as gearbox temperatures rise during a session on track. I was pretty sure the issue was a worn synchro even through the gearbox already had carbon synchros installed by PAR Engineering when the straight cut gearset was originally installed by them. I intended on farming out the job of rebuilding the gearbox but pickings are slim here in Ireland and I couldn’t find anyone that instilled any confidence when I spoke to them so decided I’d just go ahead and do it myself. The patient on the operating table For the most part the gear sets, shafts and synchros were in good order with the exception of 2nd gear. Unfortunately it appears the carbon synchro had delaminated and in turn the poor alignment had pretty much damaged all the engagement teeth on the gear itself. Its hard to see from the photos but the damage was sufficient to warrant a new 2nd gear from PAR Engineering which took a number of weeks to arrive. Damaged 2nd Gear Once the new 2nd gear arrived it was time to put it all back together Thankfully with that lot completed and a couple of track-days since reinstall under my belt I can say that 2nd gear changes are now butter smooth 4 KAS, will300, GravelRash and 1 other reacted to this Share this post Link to post Share on other sites
