Braderz26 0 Report post Posted September 4, 2019 I got a track day tomorrow 🤗 just wondering roughly what temperature people run them (hot) my tyres are Michelin PS4 Share this post Link to post Share on other sites
VAD17 479 Report post Posted September 4, 2019 I got a track day tomorrow just wondering roughly what temperature people run them (hot) my tyres are Michelin PS4 Temperature or pressure?If pressure I typically drop to 32 psi after sighting laps, then drop again to 30-31 after 1st session and keep checking so it does not go above 32 ish.Sent from my SM-G973F using Tapatalk Share this post Link to post Share on other sites
Church 209 Report post Posted September 4, 2019 Without thermal probe to compare temps of inside vs outside of tires most often i keep stock pressure, and letting out excess from tracked hot tires to revert to that. Exception being when i used tire pressures aswell to change grip front-rear bias back then during very first trackdays when i still had stock alignment (imho too understeer-ish and certainly of not enough static negative camber for track). Then i lowered pressure in fronts even more, to add grip there. Cheap tire pressure gauges are .. well, cheap, and at most fuel station stores. If you haven't one, buy one and let out excess from overheated tires as you track. Remember to pump back after end of trackday though. Share this post Link to post Share on other sites
Braderz26 0 Report post Posted September 4, 2019 Ok cheers guys, I’ll give that a go 👍 Share this post Link to post Share on other sites
Leeky 84 Report post Posted September 4, 2019 Same. I usually drop them to 32psi after the sighting laps and then monitor every so many laps afterwards to try and keep them all in the low 30’s Share this post Link to post Share on other sites
will300 812 Report post Posted September 5, 2019 I generally run them at around 30PSI when hot on track. I will also check the pressure every couple of sessions. Share this post Link to post Share on other sites
