OllyW 9 Report post Posted June 23, 2019 K&N Panel Filter: £25 + Postage (£50 New, has lifetime warranty and is washable.) Looks a little grubby but it's just off the air filter oil from the cleaning kits you can get. - MTEC Clutch Spring: £15 + Postage (£33 @ Tuning Developments) Spotless. Used for 6k miles. Clutch Spring makes your clutch a bit heavier and makes it nicer to find the bite point. I found that I had smoother shifts/downshifts whilst driving a bit more spiritedly. - Whiteline Bush (KDT926): £20 + Postage (£40 @ Fensport) Also looks a little grubby, just off the grease needed to insert the bushing. Fantastic condition still, only used for ~1-2k miles/2 months. Whiteline Bush fills the void in the standard gearbox mount. For me it got rid of the issues with not being able to get into 2nd gear when the gearbox is cold, especially in colder weather. Also gets rid of some movement of the gearbox when going over some slight bumps Can collect from Durham if you wish. Share this post Link to post Share on other sites
