matrixprotein 33 Report post Posted June 5, 2019 Hi guys, I know there's some stuff related to this but thought I'd ask as I'll be driving the car for a little while until the end of the month before I can map it. I have a 4-2-1 decat header fitted and its just thrown what I think is a CEL light. I've had it fitted for around 300 miles or so. I won't be able to do a remap until the end of the month. Do you think it will be ok driving the car like this until then or should I let it sit until remap time comes at which I will drive the car to a tuner. Sent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
Church 209 Report post Posted June 5, 2019 If that is what i think CEL type (cat readiness tests failed), then you can freely keep driving until get ecu tuned, what among other things also should disable those tests. Car won't go in limp mode, only cruise control won' t work. Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 5, 2019 It's a tomei el decat manifold. Worried about it running too leanSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted June 6, 2019 It won't run lean just because you derestricted the exhaust. You're almost certainly seeing the "where's my cat gone?" warning, but the fuelling is decided by other means. It's only if you've damaged your O2 sensors that things will get weird. Given that you have a warning light and you can't guarantee what it means, I advise you to get a code reader on it. The code reader could also tell you what the fuel trims are like by showing how far off the base map it wants to go. It's £15 well spent for immediate diagnosis. Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 6, 2019 It won't run lean just because you derestricted the exhaust. You're almost certainly seeing the "where's my cat gone?" warning, but the fuelling is decided by other means. It's only if you've damaged your O2 sensors that things will get weird. Given that you have a warning light and you can't guarantee what it means, I advise you to get a code reader on it. The code reader could also tell you what the fuel trims are like by showing how far off the base map it wants to go. It's £15 well spent for immediate diagnosis.Cheers mate, I have an obd in the glovebox of my auris. I'll give this a go and updateSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
Kodename47 446 Report post Posted June 6, 2019 P0420 - Reset the ECU and drive again until it comes on. Share this post Link to post Share on other sites
GravelRash 62 Report post Posted June 6, 2019 P2270 - O2 sensor signal stuck lean, Bank 1, sensor 2 The rear O2 sensor is having issues. Reset the CEL in the first instance and see if it comes back. Car will be ok to drive. Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 6, 2019 The warning light disappeared as I started it up today? Lol weird. I'll wait to see if it comes back. Til then, I've booked a remap Monday with fensportSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
Church 209 Report post Posted June 6, 2019 Hmm, something else but P0420? I hope header installer hasn't damaged o2 sensor. Share this post Link to post Share on other sites
Graham86 5 Report post Posted June 6, 2019 1 hour ago, matrixprotein said: The warning light disappeared as I started it up today? Lol weird. I'll wait to see if it comes back. Til then, I've booked a remap Monday with fensport Sent from my CLT-L09 using Tapatalk If it does come back, take the 2nd o2 sensor out and have it in free air. All it needs to do is get a different reading from the 1st. Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 6, 2019 Hmm, something else but P0420? I hope header installer hasn't damaged o2 sensor.I'm the header installer. And I definitely didn't damage any sensors lol. Sent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 6, 2019 i find it odd that its gone off now lol without us doing anything; i would think if a sensor was damaged or something, the light would just stay on. i wont be driving it much now from now until monday when i go for the remap. but will use it alittle over the weekend so will see what happens if it comes back Share this post Link to post Share on other sites
