DGT86R 6 Report post Posted March 23, 2019 P3 Vent Gauge Plug & play into OBD port above pedals Displays: Boost/Vacuum AFR Oil Temp Coolant Temp Intake Air Temp Throttle Position RPM Speed Battery Voltage and more Only thing you might need is longer tubing for the turbo boost sensor depending on where you mount...if you have a turbo of course https://www.fensport.co.uk/parts/toyota/gt-86/zn6/gauges/gt86-p3-gauge-self-install/ Cost £375 new from Fensport Asking for £275 including postage Location: Wolverhampton/Dudley *I WILL ONLY SELL IF I GET YOUR VENT IN EXCHANGE* Either just the flaps that are needed to be removed to fit gauge or the whole thing to make it easier (excl silver surround). Once paid, I will need you to send me your flaps/vent then when I receive, I will dispatch. Share this post Link to post Share on other sites
Andyroo104 8 Report post Posted May 21, 2019 Interested but my vent is already broken, therefore unable to send replacement.Sent from my iPad using Tapatalk Pro Share this post Link to post Share on other sites
