JohnM
Alarm issue /query
Has anybody come across the following issue with setting the alarm.
After a long run out of over 10 minutes when I try to set the alarm I get a continuous single tone to which I have to deactivate the alarm, open the boot, shut the boot and then set the alarm. This happens even when the boot has not been opened during the trip out. Its pretty much happening every time now since i have had the car.
I recently had an issue when I got a beeping a few seconds after setting the alarm. If I opened and shut the boot it worked ok.
It turned out to be the alarm button under the front bonnet which had been bent down as the bracket is made out of chocolate! I just bent it up and made sure the cap on the bonnet was still in the right place to hit the button and problem solved.
No idea why opening the boot seems to help but you problem sounds like mine so hopefully just a few minutes should sort it out.
