Fensport
Fensport 0% Finance!
52647491_2540848279322407_13635797849357
We are very pleased to now have the facility to offer you 0% finance on selected products.
You can now spread the cost of those part's you've always wanted over a 6, 9, 10 or 12 month period completely INTEREST FREE!
Labour and mapping costs can also be added to the finance. A minimum 10% deposit is required with a maximum of 50%.
Here's some examples. All prices including VAT;
Coilover Kit
BC BR Series coilover kit - £849
Installation including 4 wheel alignment - £480
Total - £1,329
Finance Example:
15% deposit - £199.35
12 monthly payments - £94.13 per month
Total - £1,329
Brake Upgrade
DBA 4000 T3 slotted discs front & rear - £598.66
Hawk high performance street pads front & rear - £190.99
Goodridge stainless steel brake hose kit - £87.95
Dot 5.1 brake fluid - £11.94
Installation - £300
Total - £1,189.54
Finance Example:
15% deposit - £178.43
12 monthly payments - £84.25 per month
Total - £1,189.54
Full Exhaust System & Remap
Cobra UEL 4-1 manifold - £705.60
Cobra over pipe - £170.10
Cobra sports cat front pipe - 423.83
Cobra resonated cat back system - £712.52
Installation - £120
NA remap with Ecutek license - £552
Total - £2,684.05
Finance Example:
15% deposit - £536.81
12 monthly payments - £178.93 per month
Total - £2,684.05
Turbo Conversion
AVO stage 1 turbo kit - £3,720
AVO breather system upgrade - £230.40
Forge upgrade recirculating dump valve - £136.80
Xtreme sports organic clutch kit - Stage 1 - £473.60
Xtreme lightweight flywheel - £353.40
Mishimoto low temperature thermostat - £50.40
Boost control valve - 3 Port - £67.20
3 bar map sensor - £125.94
Charge air temp kit - steel - £46.56
Stainless steel hose clip upgrade - £43.74
Inconel stud upgrade, turbo to manifold - £33.60
Genuine oil filter - £11.02
Oil drain plug gasket - £1.05
Millers 0W30 engine oil 6L - £110.37
Millers 75W90 gearbox oil - £57.56
Installation - £1,050
Remap with Ecutek license - £575
Total - £7,086.64
Finance Example:
20% deposit - £1,417.32
12 monthly payments - £472.44 per month.
Total - £7,086.644
Please bare in mind these are examples only. You can of course pay a larger deposit (up to 50%) to bring down your monthly payments. The products listed in the examples above can be swapped/removed/added to, to create your own packages.
If you are interested in applying for finance then feel free to drop us a message (sales@fensport.co.uk) with the parts required and we'll work out some options for you :)
