sam534
Can't seem to log in on tapatalk
I’ve been having the same problem with tapatalk. I can browse fine but it says I need to login then when I do it says no account associated with my email.
We had this problem last time the forum was having connectivity issues. Other forums are working fine!
There have been some forum updates installed, though if it's working for some and not others it is difficult to know. Mine works, first time I've tried it in six months. I'm no IT Geek though, @rob275 is your man.
Thanks Rob, hope you're feeling better like.
Messages aren't showing in Tapatalk now, but the login errors have stopped.  EDIT:  I can't actually post from Tapatalk now, it says I don't have permission to post.
Sounds like you've got your work cut out at the min, so good luck!
