JohnM
Rear parcel shelf query
Good evening.
So during the rear window being tinted the person doing the tint noticed that the rear parcel shelf wasnt fitted correctly under the left hand rear panel. I have looked and cant see why this would be out of place and there is no movement in either the shelf or the rear panel for it to slot into place. The right hand side is perfectly fitted flush to the interior panel. Any ideas on what could have caused this please.
The plastic part is pushed too far to the right, it should come over that part of the shelf.
The guy installing your tints probably hasn’t put it all back together properly.
Try pushing the shelf down while pulling the plastic out
Thanks Kas.
It was like this before they even started the tints so it came from the dealer like this. I assume there are no air bags to worry about in that area?
9 hours ago, benmmellor said:
nope - there's nothing critical behind that plastic. you should be able to just pull it back out into place as advised above.
well i tried to pull it back into place but it appears that the actual panel is bent out of shape towards the bottom, so when you pull it forward to line up with the shelf it just pulls back to the position in the pics. Any ideas what may have caused this before i strip the rear panels out to take a proper look. Thanks for the help so far.
