Rzezniq 3 Report post Posted August 22, 2019 2 hours ago, Church said: Do cossie make their own pads at all? Weren't those rebranded of some other vendor? Maybe even from one of those you mentioned as flawless ones .. No idea. They said Cosworth so I assumed they were made by them and they were the only ones I had issues with. They work good though for what they are. Share this post Link to post Share on other sites
KAS 25 Report post Posted August 22, 2019 Pagid pads come with the 'support shims'I nearly bought some from eurocarparts just for the shims, but I got the shims from brakes international for less than half the price of toyota instead. The fronts came with new boots for the sliders, but the rears didn’t. But toyota only sell them as part of a rebuild kit.Fitted new bushes to the lower pins all runs from toyota tho. 500 miles squeak free so far Share this post Link to post Share on other sites
KAS 25 Report post Posted August 23, 2019 Oh check out the uneven wear on the inside of factory discs and pads after 4 years and 32,000 miles!Most likely another reason why the rears start to squeak so much.Also, the single use carrier bolts get pretty bad which is why toyota say to replace them Share this post Link to post Share on other sites
Rzezniq 3 Report post Posted August 27, 2019 On 8/23/2019 at 10:24 AM, KAS said: Oh check out the uneven wear on the inside of factory discs and pads after 4 years and 32,000 miles! Most likely another reason why the rears start to squeak so much. Also, the single use carrier bolts get pretty bad which is why toyota say to replace them The pads look like shit but still have a lot of friction material left. Discs are a fucking disaster though. Mine were even worse and delaminated in my hands after 60k or so. Nothing wrong with bolts just surface rust. Share this post Link to post Share on other sites
Rzezniq 3 Report post Posted August 27, 2019 No es bueno. My front discs when I got the car. Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted August 27, 2019 That's not pretty! Share this post Link to post Share on other sites
