Test Drives Unlimited 278 Report post Posted October 8, 2018 Well my car has now covered 101,330 miles which have been faultless apart from the Smart Locking System that went wrong last year Have renewed the Service Contract for another 30,000 miles which is 1.5yrs servicing covered A couple of photo's taken at Spa last Tuesday.......... Just a quick question : How do you know when the Coil Packs need replacing on this car ? 2 Church and Lauren reacted to this Share this post Link to post Share on other sites
Lucas 244 Report post Posted October 8, 2018 Usually you'd get an engine check light and/or slight misfire. 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted October 8, 2018 Thank for the reply Lucas Sent from my ASUS_A001 using Tapatalk Share this post Link to post Share on other sites
gavin_t 184 Report post Posted October 8, 2018 Hope you are still enjoying it. Hope you enjoyed spa as well. My mate was on that day and thoroughly enjoyed it despite the rain 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
surrey86 352 Report post Posted October 8, 2018 What was the track like in the wet Nigel? Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted October 8, 2018 Spa-Francorchamps was good again apart from being very wet Took 12 cars to the Event with the "Gang Bang Car Club" that am a Founder Member of We attend Track Days at UK Circuits, Nurburgring and Spa-Francorchamps Sent from my ASUS_A001 using Tapatalk Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted October 8, 2018 It's alright Nigel, non-rotaries can usually tell when the sparks are not happening. It only gets troublesome when you have more than one plug per cylinder. 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Montatron 15 Report post Posted October 8, 2018 It is really good to see that a few guys have gone over the 100k mark with no major problems 🙂 it give me hope when mine goes that high 😜 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 8, 2018 That's great, Nigel. I'm currently just over 120K in five and a half years. I'm surprised you haven't done a coilpack yet, I've had all mine replaced by 110K miles. It will throw an EML. Coil packs are £87 plus fitting (it's a 15 minute job). Other issues in that mileage, wheel bearing at 110K miles, CV joint at 70K miles. Had the heated seat switch illumination go twice, didn't bother to get it sorted the second time round as the seat still heats fine, it's just a light. 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted October 9, 2018 Thanks Lauren and will keep an eye on the Coil Packs Sent from my ASUS_A001 using Tapatalk Share this post Link to post Share on other sites
gavin_t 184 Report post Posted October 10, 2018 On 08/10/2018 at 6:56 PM, Lauren said: That's great, Nigel. I'm currently just over 120K in five and a half years. I'm surprised you haven't done a coilpack yet, I've had all mine replaced by 110K miles. It will throw an EML. Coil packs are £87 plus fitting (it's a 15 minute job). Other issues in that mileage, wheel bearing at 110K miles, CV joint at 70K miles. Had the heated seat switch illumination go twice, didn't bother to get it sorted the second time round as the seat still heats fine, it's just a light. I have heard that the coil packs may be more of an issue when aftermarket manifolds are fitted. Not sure if Nigel has one fitted or not? Think it is the heat that kills them off Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 10, 2018 3 hours ago, gavin_t said: I have heard that the coil packs may be more of an issue when aftermarket manifolds are fitted. Not sure if Nigel has one fitted or not? Think it is the heat that kills them off Nigel's car is stock. I have had one go with the TD manifold, the other three perished in the first 100K before it was fitted, so that doesn't ring true as such. I would say it's more down to how hard you drive it. Really buzzing it near the redline on change up is what seems to bring on the EML for the coil pack. Nigel has an auto so harder to do I would say. Out of the four coilpacks that went, I noticed nothing other than the EML with the first three but the last one to go, failed completely and I was running on three cylinders. It threw an EML when I started my car on the morning of the TSS. Then went off. Did a second run and it came on again and it was then running on three cylinders. Share this post Link to post Share on other sites
surrey86 352 Report post Posted October 10, 2018 It makes sense that an aftermarket overpipe won't help, due to the proximity and loss of heat shield Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted October 11, 2018 My car performed faultless at Thruxton on Tuesday I have a full one off custom built exhaust system on the GT86 from engine bay to the back of the car and it read 85db on the noise test Share this post Link to post Share on other sites
