sagecalla 0 Report post Posted April 9, 2018 Ordered a 12 piece duraflex wide body awhile back, just wanting some advice on what size wheel/tire would fit and recommendations on coilovers as well. Share this post Link to post Share on other sites
nikndel 509 Report post Posted April 9, 2018 Has anyone on here got that kit? Share this post Link to post Share on other sites
Kodename47 446 Report post Posted April 9, 2018 1 hour ago, nikndel said: Has anyone on here got that kit? It's a copy of the RocketBunny kit so @adamj29 might have the answer. Share this post Link to post Share on other sites
Paul 442 Report post Posted April 9, 2018 Adam had to cut half his normal arches apart to get his wheels to fit, might not be the best example! 1 adamj29 reacted to this Share this post Link to post Share on other sites
Kodename47 446 Report post Posted April 10, 2018 11 hours ago, Paul said: Adam had to cut half his normal arches apart to get his wheels to fit, might not be the best example! You pretty much have to do that with the RB kit if you want the complete look. @sagecalla the best bet is to go and look over in the US forum where loads have fitted the kit. Share this post Link to post Share on other sites
adamj29 133 Report post Posted April 11, 2018 On 4/10/2018 at 8:17 AM, knightryder said: You pretty much have to do that with the RB kit if you want the complete look. @sagecalla the best bet is to go and look over in the US forum where loads have fitted the kit. Yeah the US forum are the best place for advise on spec for wide body kits. Other than the standard cutting / grinding and welding required to fit the arches, I needed extensive modifications to be carried out to the front arches as there was too much negative offset on them. They eventually fitted. My wheel specs are: Front - 18 x 9.5 ET -36 Rear - 18 x 10.5 ET -47 The rear wheels needed around -5.5 camber to get them to fit. So if you want to use it for the track, or as a practical car then go for more positive offset. But at least you know the limitations of what can be used. 2 Quball and TomG94 reacted to this Share this post Link to post Share on other sites
