Simon86 1 Report post Posted February 1, 2018 So I noticed a wet oil patch around this area and what looks like an oil trail on the exhaust at the back of the engine. What is is this part called and will it be covered under warranty? If not might have to break out the AA warranty. Had an engine rebuild a year ago and had done 20,000+ miles Share this post Link to post Share on other sites
Varelco 211 Report post Posted February 1, 2018 The old cam cover oil plate leak. A common issue. Yeah it will be covered by warranty. There are better quality aftermarket options out there for it too. Share this post Link to post Share on other sites
Simon86 1 Report post Posted February 1, 2018 7 minutes ago, Varelco said: The old cam cover oil plate leak. A common issue. Yeah it will be covered by warranty. There are better quality aftermarket options out there for it too. Thank you for your reply. I’m going to book it in as I’m still under warranty Share this post Link to post Share on other sites
Simon86 1 Report post Posted February 1, 2018 Will this get much worse or will it be just a dripping issue Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 1, 2018 6 hours ago, Simon86 said: Will this get much worse or will it be just a dripping issue It should just drip. But best to get it sorted when you can as the manifold is below and oil dripping onto the manifold is always going to be a bit dodgy! Torqen in the traders section had an uprated cam plate they offer for a decent price so maybe worth getting one of those fitted which should solve the problem permanently. Share this post Link to post Share on other sites
vanko25 70 Report post Posted February 1, 2018 That's not the camplate. This is a blanking plate where the vacuum pump for the auto is supposed to be. It's at the back of the engine on the driver's side if I am not wrong? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 1, 2018 12 minutes ago, vanko25 said: That's not the camplate. This is a blanking plate where the vacuum pump for the auto is supposed to be. It's at the back of the engine on the driver's side if I am not wrong? That's the one but it does always seem to be referred to as the cam plate? Share this post Link to post Share on other sites
vanko25 70 Report post Posted February 1, 2018 Aa okay. I always thought we only call the front cam plates like that Share this post Link to post Share on other sites
KevinA 695 Report post Posted February 1, 2018 I fitted this, problem solved Share this post Link to post Share on other sites
dom2497 33 Report post Posted February 3, 2018 How much was it if you dont mind me asking. I think mine might be weeping...Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
