Gary p 46 Report post Posted July 25, 2017 Just had the tein coilovers fitted and what a difference it's made to the car 👌👌 would reccomend these to anyone that's wishing to change there set up. Only problem I have is having 9.5 j rims and catch inner arch on full lock due to camber but can be sorted with 2mm spaces or adjusted camber. Heres a picture of how it sits 2 Lauren and HariboPenguin reacted to this Share this post Link to post Share on other sites
Cerastes 204 Report post Posted July 25, 2017 I'm getting those, one day. I just can't commit to spending that much all in one go. Unless I can find a bargain. Share this post Link to post Share on other sites
Gary p 46 Report post Posted July 25, 2017 24 minutes ago, Cerastes said: I'm getting those, one day. I just can't commit to spending that much all in one go. Unless I can find a bargain. Well worth it buddy feels a lot more positive braking has improved too👍👍 Share this post Link to post Share on other sites
jimmyjimmyjimmy_ 32 Report post Posted July 26, 2017 15 hours ago, Cerastes said: I'm getting those, one day. I just can't commit to spending that much all in one go. Unless I can find a bargain. Definitely worth it, after an alignment the car feels a lot nicer to drive and there's always the looks as well 1 Gary p reacted to this Share this post Link to post Share on other sites
KevinA 695 Report post Posted July 26, 2017 9.5's here on Teins no probs at all. Share this post Link to post Share on other sites
Gary p 46 Report post Posted July 26, 2017 1 hour ago, KevinA said: 9.5's here on Teins no probs at all. Not sure what the ET is on my alloys may sit in a little closer than yours. It only rubs when the steering is locked out to its maximum point. The camber may need taking out a little to compensate so the tyre doesn't scrub 😁 Share this post Link to post Share on other sites
Special K 442 Report post Posted July 26, 2017 Gary - do you have adjustable camber? Or are you on stock? I don't think spacers will cure your issue, especially when cornering hard. Look to set 2.0 - 2.5degrees negative on fronts, half a degree less on rears. Only my view. Spec K Share this post Link to post Share on other sites
Gary p 46 Report post Posted July 26, 2017 30 minutes ago, Special K said: Gary - do you have adjustable camber? Or are you on stock? I don't think spacers will cure your issue, especially when cornering hard. Look to set 2.0 - 2.5degrees negative on fronts, half a degree less on rears. Only my view. Spec K Yeah that's about what I have up front will have a look at the print off of the camber settings when it went for the 4 wheel alignment it maybe the case of too much camber. Will check shortly👍👍 Share this post Link to post Share on other sites
Gary p 46 Report post Posted July 26, 2017 @Special K just looked front camber set at 2.29 Share this post Link to post Share on other sites
Gary p 46 Report post Posted July 27, 2017 On 26/07/2017 at 11:59 AM, KevinA said: 9.5's here on Teins no probs at all. What size tyres do you run up front? Iam currently on 245/40/18 Share this post Link to post Share on other sites
KevinA 695 Report post Posted July 27, 2017 My spec is 18x9.5 et35 running 245/40/18 Tein Monosport with 25mm drop from OEM. Front camber -2.5° and rear -2.0 1 Gary p reacted to this Share this post Link to post Share on other sites
Gary p 46 Report post Posted July 28, 2017 23 hours ago, KevinA said: My spec is 18x9.5 et35 running 245/40/18 Tein Monosport with 25mm drop from OEM. Front camber -2.5° and rear -2.0 Have a feeling the ET maybe 38 on the rota grids Iam due for a tyre change so didn't know whether to go for 245/35/18 to see if that made any difference before altering camber? Not sure if it will or not!! Share this post Link to post Share on other sites
KevinA 695 Report post Posted July 28, 2017 Dropping to a 35 profile will help, I would have too but my tyres are not available in that profile. 1 Gary p reacted to this Share this post Link to post Share on other sites
Foulsmell 120 Report post Posted July 29, 2017 I'm thinking of getting these but I don't want it slammed to the floor. Does anyone know what the highest ride height would be? Share this post Link to post Share on other sites
KevinA 695 Report post Posted July 29, 2017 You can run sensible height as well. 2 Gary p and Foulsmell reacted to this Share this post Link to post Share on other sites
AJ124 118 Report post Posted July 31, 2017 On 29/07/2017 at 8:44 AM, Foulsmell said: I'm thinking of getting these but I don't want it slammed to the floor. Does anyone know what the highest ride height would be? Mine are set at 15-20mm lower than standard if that helps. 1 Foulsmell reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted July 31, 2017 Mine are set 15 mm below standard, and it's fine for clearance. 1 Gary p reacted to this Share this post Link to post Share on other sites
Ztox 230 Report post Posted August 22, 2017 Bit late to the party @Gary p but I'm on 9.5 wide ET38 with 235/40 tyres and -2.5deg front camber and -2deg rear, no issues at all. Share this post Link to post Share on other sites
Lucas 244 Report post Posted August 22, 2017 How low is it sitting on that picture? Have you got a measurement? @Gary p Share this post Link to post Share on other sites
Tareim 343 Report post Posted August 22, 2017 are you still on the stock drop links? if so are you sure its the tyres/wheels rubbing on full lock? when I had teins fitted with stock drop links and a fair amount of camber the standard drop links would catch the inner arch/engine bay on full lock Share this post Link to post Share on other sites
Gary p 46 Report post Posted August 22, 2017 11 hours ago, Ztox said: Bit late to the party @Gary p but I'm on 9.5 wide ET38 with 235/40 tyres and -2.5deg front camber and -2deg rear, no issues at all. I may try 245/35 as it's the tyre that catches inner arch. Does the 235/40 look stretched on that width of alloy? Have you a pic to see how it looks if you don't mind😁 Share this post Link to post Share on other sites
Gary p 46 Report post Posted August 22, 2017 11 hours ago, Tareim said: are you still on the stock drop links? if so are you sure its the tyres/wheels rubbing on full lock? when I had teins fitted with stock drop links and a fair amount of camber the standard drop links would catch the inner arch/engine bay on full lock Still on stock mate it's definitely the tyre scrubbing I can see the mark where it catches. Share this post Link to post Share on other sites
Gary p 46 Report post Posted August 22, 2017 11 hours ago, Lucas@PartBox said: How low is it sitting on that picture? Have you got a measurement? @Gary p Not sure buddy to be honest with you without measuring stock. I just lowered them to a point where I was happy. I would say there prob around 35mm maybe a little more Share this post Link to post Share on other sites
KevinA 695 Report post Posted August 22, 2017 24 minutes ago, Gary p said: I may try 245/35 as it's the tyre that catches inner arch. Does the 235/40 look stretched on that width of alloy? Have you a pic to see how it looks if you don't mind😁 1 Ztox reacted to this Share this post Link to post Share on other sites
Gary p 46 Report post Posted August 22, 2017 @KevinA they sit lovely on 235/40 don't they this maybe an other option to look into. Thanks again👍 Share this post Link to post Share on other sites
