Andrew Smith 156 Report post Posted June 11, 2017 I have bought the Torque app and a OBD2 plug thingy to monitor oil temps but I cant get it to work. I have set up the PID as suggested in a few threads but no joy. A search around the interweb has come up with nothing. Other guages are working fine Any ideas? Thanks Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted June 11, 2017 Post up the specifics of your "oil temp" PID and I'll compare it with mine. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 11, 2017 The only other thing I can think of is that the Ecutek remap isn't compatible Share this post Link to post Share on other sites
Rich 378 Report post Posted June 11, 2017 I had a really cheap OBD2 reader that didn't show oil temps (but did show other stuff). Switching to a slightly more expensive one fixed the issue. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 11, 2017 That is good to know Rich, mine cost me about 8 beer tokens so it wasnt a great deal of money. I believe I have my settings right so perhaps I should pry my wallet open a bit further Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted June 12, 2017 Have it working fine on Android with Dashcommand, just working out mounting options. Used another bit of software to auto unlock the phone and boot dashcommand when the car starts (and the opposite when the car is turned off) Makes good use of an old phone Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Rich 378 Report post Posted June 12, 2017 9 hours ago, Andrew Smith said: That is good to know Rich, mine cost me about 8 beer tokens so it wasnt a great deal of money. I believe I have my settings right so perhaps I should pry my wallet open a bit further My cheap one cost £3.75 and looked like this: My slightly more expensive one was £9 and looked like this: Apparently the larger ones tend to be better. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted June 12, 2017 @Andrew Smith The only difference between your settings and mine are that I didn't put a unit on the reading (that you have as "C"). I don't think it should matter, so perhaps your beer-tastic dongle isn't taking instructions. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
un1eash 9 Report post Posted June 12, 2017 I've had problems with the newer v2.1 bluetooth obd2 dongle reading codes but my old v1.5 works fine. Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 12, 2017 I have ordered another dongle, the same as the one Rich has but I shall also try omitting the 'C' from the unit type. Will have to wait until later in the week for the result as the car is in for a service. I have Riceburners Yaris at present ⛐ Share this post Link to post Share on other sites
Ztox 230 Report post Posted June 13, 2017 I have the C unit type and it works fine @Andrew Smith. I also have a dongle that looks very much like Rich's. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 13, 2017 3 hours ago, Ztox said: I have the C unit type and it works fine @Andrew Smith. I also have a dongle that looks very much like Rich's. This sounds promising, I will give it a try when the new dongle arrives. Thanks Share this post Link to post Share on other sites
Mike 458 Report post Posted June 13, 2017 I went through about 3 of the cheapo ones from eBay where they'd either stop working completely or would be intermittent and so be useless. Ended up getting one of these - https://www.amazon.co.uk/dp/B00H9S71LW/ref=pe_385721_37986871_TE_item (not at that price though!) - and it works fine. Will happily log at 0.1s which isn't entirely useful because Excel throws a hissy fit at the amount of data in the CSVs Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted June 13, 2017 I have a vgate unit, wifi, cost £10 and does Toyota PID. Had it for 4 years with no issues Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
KevinA 695 Report post Posted June 13, 2017 This what I use, works great engine was cold just on the drive ambient readings. 1 Gringosteve reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted June 14, 2017 17 hours ago, Mike said: I went through about 3 of the cheapo ones from eBay where they'd either stop working completely or would be intermittent and so be useless. Ended up getting one of these - https://www.amazon.co.uk/dp/B00H9S71LW/ref=pe_385721_37986871_TE_item (not at that price though!) - and it works fine. Will happily log at 0.1s which isn't entirely useful because Excel throws a hissy fit at the amount of data in the CSVs 0.1s is good. I put mine on log as fast as they update and it's about 0.3s per update. Share this post Link to post Share on other sites
Mike 458 Report post Posted June 14, 2017 1 hour ago, Rich said: 0.1s is good. I put mine on log as fast as they update and it's about 0.3s per update. Had a look at the data, it might be logging at 0.1 but values aren't changing that often. Might change to log as often as they update... Share this post Link to post Share on other sites
Ade 517 Report post Posted June 14, 2017 21 hours ago, Mike said: I went through about 3 of the cheapo ones from eBay where they'd either stop working completely or would be intermittent and so be useless. Ended up getting one of these - https://www.amazon.co.uk/dp/B00H9S71LW/ref=pe_385721_37986871_TE_item (not at that price though!) - and it works fine. Will happily log at 0.1s which isn't entirely useful because Excel throws a hissy fit at the amount of data in the CSVs I have one of these too. This is what the knock offs are knocking off. It works effortlessly and when using it to display something like fuel line pressure it updates fast enough to be useful. Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 15, 2017 The Vgate scanner arrived so I excitedly plugged it in and just like the last dongle... no oil temp. Not sure if I can be bothered to persue this any more, I might just install a proper guage at some point Share this post Link to post Share on other sites
Guest Report post Posted June 16, 2017 8 hours ago, Andrew Smith said: The Vgate scanner arrived so I excitedly plugged it in and just like the last dongle... no oil temp. Not sure if I can be bothered to persue this any more, I might just install a proper guage at some point I've literally just bought one also. Tried to find the option for oil temp, but i couldn't find it. Not sure if you have to buy additional plugins? Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 16, 2017 1 hour ago, don said: I've literally just bought one also. Tried to find the option for oil temp, but i couldn't find it. Not sure if you have to buy additional plugins? I have got mine working this morning, no need for a plugin. Set up a custom PID using the settings I posted near the top of this page with the exception of the long and short name, call it someting you will recognise. I called mine 'Andys Oil Temp' Go to realtime information and select the guage that appeals to you and then from the menu that will appear, select your custom PID. All being well you should have a working oil guage Share this post Link to post Share on other sites
Rich 378 Report post Posted June 16, 2017 You need to not call it "Oil Temperature" I think as there's already a sensor for this using the same name. Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted June 16, 2017 11 minutes ago, Rich said: You need to not call it "Oil Temperature" I think as there's already a sensor for this using the same name. Absolutely, this is where I went wrong. Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted June 16, 2017 19 minutes ago, Andrew Smith said: I have got mine working this morning, no need for a plugin. Set up a custom PID using the settings I posted near the top of this page with the exception of the long and short name, call it someting you will recognise. I called mine 'Andys Oil Temp' Go to realtime information and select the guage that appeals to you and then from the menu that will appear, select your custom PID. All being well you should have a working oil guage Andy if you're passing by, drop in and i'll take a look for you. Ours picks up Oil Temp no issue. Mike Share this post Link to post Share on other sites
Mike 458 Report post Posted June 16, 2017 20 minutes ago, Rich said: You need to not call it "Oil Temperature" I think as there's already a sensor for this using the same name. I've got mine as "Oil temperature", must be case sensitive! Share this post Link to post Share on other sites
