Subota Boy 402 Report post Posted May 9, 2017 Considering 18 inch wheels, but I would like a tyre profile that would raise the ground clearance of the car, as sometimes over speed bumps my Cosworth exhaust grounds slightly, and i don't want to make this worse. Car is lowered one inch on Eibachs. I know this will compromise sidewall flex and handling, but they are less of a priority for me. Any help greatfully received. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted May 9, 2017 225/40 is often used on 18's (I'm assuming 8" wide) and will raise the car 5.95mm and will only alter the speedo reading by 1.87% 1 Subota Boy reacted to this Share this post Link to post Share on other sites
jevvy 40 Report post Posted May 9, 2017 Buy my Yokohamas in my post! Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 9, 2017 Go for some 255/60, that'll give you some clearance 3 Mike, Subota Boy and TTR reacted to this Share this post Link to post Share on other sites
Blameshift 2 Report post Posted September 13, 2017 On 09/05/2017 at 1:06 PM, Deacon said: 225/40 is often used on 18's (I'm assuming 8" wide) and will raise the car 5.95mm and will only alter the speedo reading by 1.87% In what way? If you're driving 40mph will it read 38 or 42? In what way does it alter the bigger wheels you have? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted September 13, 2017 9 minutes ago, Blameshift said: In what way? If you're driving 40mph will it read 38 or 42? In what way does it alter the bigger wheels you have? Try this website. If you enter the size you are looking at it will tell you all the details you need:- http://www.willtheyfit.com Share this post Link to post Share on other sites
gavin_t 184 Report post Posted December 21, 2017 Running 225/40 18 on mine lowered on the same springs as you and find the fitment and drive spot on compared to the stock wheel size. PS mine are 8.5inch wide so have a little stretch. Fitment would be perfect on 8inch and nice and square Share this post Link to post Share on other sites
