Minion 132 Report post Posted February 27, 2017 I'm looking at 'De-Bricking' my 86 but just looking to see if there was a guide on here how to do it. I haven't really looked into it much yet other than a quick browse on the search bar. I already have my 3/4 plate ready to put on but just need to take the big ugly brick off now. Thanks Jake Share this post Link to post Share on other sites
surrey86 352 Report post Posted February 27, 2017 You just need to undo 2 number plate screws, and 2 brick screws iirc. Then either stick on your new plate or drill a couple holes in it to the brick's mounting holes. 1 Minion reacted to this Share this post Link to post Share on other sites
S18 RSG 429 Report post Posted February 27, 2017 30 minutes ago, Minion said: I'm looking at 'De-Bricking' my 86 but just looking to see if there was a guide on here how to do it. I haven't really looked into it much yet other than a quick browse on the search bar. I already have my 3/4 plate ready to put on but just need to take the big ugly brick off now. Thanks Jake It's pretty straight forward. Once you've removed the front plate, there are two screws holding the "brick" in place. Just undo them, then remove the screw thread clips and you're done. I drilled holes in my plate in the same locations as the holes for the brick, and used slightly larger white bolts to hold it. Works well. 1 vanko25 reacted to this Share this post Link to post Share on other sites
Minion 132 Report post Posted February 27, 2017 Just now, maurice said: You just need to undo 2 number plate screws, and 2 brick screws iirc. Then either stick on your new plate or drill a couple holes in it to the brick's mounting holes. 1 minute ago, S18 RSG said: It's pretty straight forward. Once you've removed the front plate, there are two screws holding the "brick" in place. Just undo them, then remove the screw thread clips and you're done. I drilled holes in my plate in the same locations as the holes for the brick, and used slightly larger white bolts to hold it. Works well. Wow I didn't realise it was this simple, I'll have a look at it tonight and hopefully it turns out as good as I imagine. Thanks Guys Share this post Link to post Share on other sites
