Sideways? 33 Report post Posted November 26, 2014 Did anyone take up this offer in the end?? I noticed you put some photos of the fitting instructions on the first page, but I can't seem to find them to download and see just how much work is involved... Looking into the rear subframe mounts and so on it actually doesn't look too complicated and almost like nothing major needs to be removed - so I'm still interested if no-one else has taken the plunge already of course Could you please either post a link to download the fitting instructions, or post some larger photos so I can confirm my current thoughts Cheers!! Share this post Link to post Share on other sites
Quixote 35 Report post Posted December 16, 2014 However we do not know which one as quite rightly so, it is patent protected like the concept of the product itself. During the patent application process (typically 18 months from the priority date for my patent applications) the patent application is published in order for others to make counter claims and potentially fight for dismissal. Therefore, if it is patent protected, the manufacturer should list the patent or application number(s) associated to protect themselves - this should apply to materials as well as "concept". Patent applications also take many years from concept to grant, so if the manufacturer only recently launched this product, I'd expect it still to be "patent pending" although the material used may well have a grant. So, in short, "patent protected" is not the same as "not public/published" - in fact if it's patent protected, it will be public domain information. Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted December 17, 2014 Did anyone take up this offer in the end?? I noticed you put some photos of the fitting instructions on the first page, but I can't seem to find them to download and see just how much work is involved... Looking into the rear subframe mounts and so on it actually doesn't look too complicated and almost like nothing major needs to be removed - so I'm still interested if no-one else has taken the plunge already of course Could you please either post a link to download the fitting instructions, or post some larger photos so I can confirm my current thoughts Cheers!! Hello, no on has taken us up yet. Partly my fault. We have all the kits here now so shout if your interested. During the patent application process (typically 18 months from the priority date for my patent applications) the patent application is published in order for others to make counter claims and potentially fight for dismissal. Therefore, if it is patent protected, the manufacturer should list the patent or application number(s) associated to protect themselves - this should apply to materials as well as "concept". Patent applications also take many years from concept to grant, so if the manufacturer only recently launched this product, I'd expect it still to be "patent pending" although the material used may well have a grant. So, in short, "patent protected" is not the same as "not public/published" - in fact if it's patent protected, it will be public domain information. Thanks for that. Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted December 17, 2014 Where are you located? Do you have a garage in mind for installation, or would you be confident installing yourself? Can you carry out the works and complete a write up within 2 weeks? I would suggest a process of: 1. GEO check - Adjustment shouldn't be necessary if correctly aligned already, just a print out to show current set up. 2. Vehicle test drive 3. Install Collars 4. GEO check and print out after collar installation. Then adjust to manufacturer specification or as per initial inspection and print out. 5. Vehicle test drive Obviously the whole installation would need to be documented with images. I am looking for a good honest report from someone that appreciates refined handling. As in the post above. We are offering one front and rear set for testing. Here are the installation instructions. They have been loosely translated to english!!! Share this post Link to post Share on other sites
Sideways? 33 Report post Posted December 17, 2014 Super, thanks for the instructions! Doesn't look too tricky, I can't commit until after Christmas, but I hope I can take up your offer... Speak to you in the new year :-) Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted April 30, 2015 Still not had a taker on these. Amazing! Share this post Link to post Share on other sites
Lauren 2259 Report post Posted May 1, 2015 If no-one has taken it up, there must be a reason. I admit, I've felt no need to stiffen my chassis, I think it's stiff enough already. I do wonder how superflous a lot of bracing is, though I understand this is not bracing. Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted May 5, 2015 These are not just to stiffen the chassis. The reason they have not been taken up yet as they are an unknown. I am still willing to let someone have a set in return for a write up. Watch the video. http://youtu.be/zWyUD6UXfog Share this post Link to post Share on other sites
Sideways? 33 Report post Posted June 1, 2015 Right, had my alignment done on Saturday, I'll try to post the before and after figures when I get time... Given that it has taken me this long (i.e. since December when I said I couldn't commit until after Christmas, and my little man was born) to get the alignment done, it might take me a while to get the collars fitted and then have the alignment checked again, but if that sort of timeframe is not too much of a problem then send a set over and I'll have them fitted and organized from there...! Oh, and can anyone point me in the right direction for the torque requirements for the bolts to be removed in the instructions?? 1 Keethos reacted to this Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted June 3, 2015 Right, had my alignment done on Saturday, I'll try to post the before and after figures when I get time... Given that it has taken me this long (i.e. since December when I said I couldn't commit until after Christmas, and my little man was born) to get the alignment done, it might take me a while to get the collars fitted and then have the alignment checked again, but if that sort of timeframe is not too much of a problem then send a set over and I'll have them fitted and organized from there...! Oh, and can anyone point me in the right direction for the torque requirements for the bolts to be removed in the instructions?? Replied to PM Share this post Link to post Share on other sites
Sideways? 33 Report post Posted June 11, 2015 So, I did say things happen slowly in my part of the world.... Anyway, have some before and after alignment readings, you can see that my rear toe was out, and I think that is why it felt a bit more frisky than "normal" at the rear... Needless to say it is now much nicer to drive and the rear doesn't seem to snap out quite so much as before the alignment... Anyone found the torque readings for the bolts to drop the subframe yet?? 1 Burn! Motorsport reacted to this Share this post Link to post Share on other sites
Jamie_GRMN 177 Report post Posted June 11, 2015 The Four bolts that hold the subframe to the car are 145Nm, the repair manual also says a new bolt should be used. The two bolts on each side that hold the brace on the front in place are 70Nm, bolts can be reused Hope that helps mate 2 Sideways? and Burn! Motorsport reacted to this Share this post Link to post Share on other sites
Sideways? 33 Report post Posted June 11, 2015 The Four bolts that hold the subframe to the car are 145Nm, the repair manual also says a new bolt should be used. The two bolts on each side that hold the brace on the front in place are 70Nm, bolts can be reused Hope that helps mate Cheers, I finally did some digging and found the 5009 page manual on the FT86 Club forum... Which manual did you use? I reckon front crossmember details are on page 3209, and rear subframe are on page 3250 of the FT86 Club mega PDF. As you mention, those figures are for the rear subframe, I believe fronts are 60Nm for the blue circled bolts, and 95 Nm for F1 & F2.. I'm going to have to see where to get the bolts from and how much they are, as well as decide if I think it can be wiggled enough to mean I don't need to take half the car apart to slip the collars in... Fun all round :-) Share this post Link to post Share on other sites
Jamie_GRMN 177 Report post Posted June 11, 2015 I used the system I have access to through work, will be the same as the mega pdf I guess, just online and not one file so can browse and find things. Sorry forgot to confirm the front, but that sounds about right. 1 Sideways? reacted to this Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted June 11, 2015 Good infos here. Let me know when your ready for the collars :-) Share this post Link to post Share on other sites
Sideways? 33 Report post Posted June 12, 2015 @Jamie_gt86 : can you get the part numbers for the bolts that should be replaced?? That 5,009 page pdf is a flipping nightmare... Share this post Link to post Share on other sites
Jamie_GRMN 177 Report post Posted June 12, 2015 Give me till Monday (I've left work now and about to head to Dublin) and I'll get the install instructions for the front and rear, will have all torques & part numbers on and sequences etc. Just send me a PM with your email address and I'll send the PDF's over 1 Sideways? reacted to this Share this post Link to post Share on other sites
Sideways? 33 Report post Posted June 12, 2015 Give me till Monday (I've left work now and about to head to Dublin) and I'll get the install instructions for the front and rear, will have all torques & part numbers on and sequences etc. Just send me a PM with your email address and I'll send the PDF's over Super, ta! PM en route... Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted July 3, 2015 Just wanted to pop a quick post on here as we have sold 15!! Sets in the last two days for the GT86 / BRZ alone. That alone tells me that they are worth it. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted July 3, 2015 Any sign of a review? Share this post Link to post Share on other sites
Kodename47 446 Report post Posted July 3, 2015 If you use the code SPC_ASLMT15U you get more of a discount Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted July 3, 2015 If you use the code SPC_ASLMT15U you get more of a discount That's funny. That code is nearly used up. Share this post Link to post Share on other sites
DanJ 374 Report post Posted July 5, 2015 Having just watched the video for these I have to say that in my opinion this is total hogwash, they do not understand bolted joint theory at all (to be fair most people don't, but then most people aren't trying to sell products like this!) the "test" driving over the green brick in particular is just nonsense. An M12 bolt holding a subframe on will be classed as safety critical and so will be at least grade 8.8 and probably grade 10.9, being generous and assuming its an 8.8 then the preload in the joint will be at least 20kN (the same as a 2000kg weight pushing the bush inner collar against the body) I'd be really concerned that as the collars are aluminium they will fret over time, which could ultimately result in loss of preload, which could eventually lead to lateral forces being reacted by the combined shear strength of the collar and the bolt. My apologies to the seller but as a qualified engineer who has direct experience in specifying safety critical bolted joints I advise everyone to steer clear. 1 Gringosteve reacted to this Share this post Link to post Share on other sites
BigJames 15 Report post Posted July 9, 2015 If the offer is still on to test a set for free in exchange for a write-up etc... fire me a PM. I've heard VERY good things about these from friends in Japan, assuming they are the Spoon variant and not another brand. 1 Burn! Motorsport reacted to this Share this post Link to post Share on other sites
Burn! Motorsport 20 Report post Posted August 19, 2015 Loads back in stock. Code higher in the thread is still going and I will still honour the offer of a free set to a tester that will write up and document. And yes these are the original Spoon Sports rigid collars and not some copy or replica. Share this post Link to post Share on other sites
