Lauren 2259 Report post Posted October 31, 2020 15 minutes ago, Luke said: Those brakes look great tucked behind RPF1’s! Are the calipers rotated up from the oem position? If so I wonder why? No they are not, they mount to the stock position. 1 Luke reacted to this Share this post Link to post Share on other sites
Booboo 11 Report post Posted October 31, 2020 What is this Custom headlight adjuster for lowered cars you speak off? I could do with a solution to mine Share this post Link to post Share on other sites
Deacon 1357 Report post Posted October 31, 2020 23 minutes ago, Booboo said: What is this Custom headlight adjuster for lowered cars you speak off? I could do with a solution to mine It's basically this:- https://www.amber-performance.co.uk/product.php?xProd=25550 Share this post Link to post Share on other sites
Booboo 11 Report post Posted November 2, 2020 On 10/31/2020 at 8:56 PM, Deacon said: It's basically this:- https://www.amber-performance.co.uk/product.php?xProd=25550 Cheers fella 1 Deacon reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted November 13, 2020 Fitted a switched OBD2 port extender. I ran it behind the stereo and into the glovebox. When I wanted to use an OBD2 reader mine could be a bit temperamental sometimes and I'd read using an extender could sort this. Being switched also means I can just leave the obd2 port reader in all the time without any worry of battery drain or throwing codes. Finally, it's also just much easier to access now! 1 Lauren reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 9, 2021 A little interior tweek which I picked up from a member on the other forum - leather shift boot with 86 embroidery to replace the OEM vinyl one and a Type R style Duracon shift knob (to add to the far too many shift knobs I now own) 1 BRZ-123 reacted to this Share this post Link to post Share on other sites
