Deacon
Deacons '86
1 hour ago, Deacon said:
Mine are the Maxgaurd Racegaurd Composites (as per the pictures) and came from eBay 👍
I have these came in at £43 would be interesting to see how many companies make them
My cars having a regular maintenance wash done since it was detailed as their prices are crazyy good and it saves me trying to try and find the time to do it. Had the inside and outside done this time.Screenshot_20201004-210234.thumb.jpg.f30797fd8a946553235126de6f907c2b.jpgIMG_20200926_203738_755.thumb.jpg.a26100ae1e4e617bf492560f7cd7e70a.jpgIMG_20200927_131302.jpg.ae49f7d631faffaad3ba267fecfea9a6.jpgIMG_20200926_161226.thumb.jpg.6dcccabc69eea8cdfbfc1e59e423819f.jpgIMG_20200927_144051_526.thumb.jpg.9166651845e50c95893f7313a0641173.jpg
Bought some new front brake pads as my PFC.08's were starting to get a bit past it after 10 trackdays on them.
I've gone for PFC's again but PFC.11 this time which are meant to have even better braking performance at the cost of a little longevity.
The braking on the PFC.08's is fantastic so the fact these are supposed to be even better is something I'm struggling to comprehend.
These, along with a couple of other little changes, should hopefully give me pretty decent braking for my final trackday of the year at the club day on the 21/11.
I collected the rest of the brake upgrade todayIMG_20201017_120614.jpg.1f46b1c3f6e65e4de41232f4065fcc8d.jpg
I've gone with the Reyland AP BBK with curved internal vein J hook discs. These should hopefully work very nicely with the PFC.11 pads and Motul RBF660 fluid.
Discs are 330mm
29 minutes ago, Kaltorak said:
I thought you already had a bbk? Or am I just going insane!
No, been on stock brakes with steel lines, better fluid and track pads up until this goes on.
11 minutes ago, Lauren said:
Best mod ever if you track your car. 👍
I'd be putting money on an oil cooler before a BBK for the track. Oil was getting beyond 125C before the brakes even had a chance to fade otherwise.
Wow, nice! How did you find they held up on a long stint? Many issues?
No problems with the right pads. Only swapped to the BBK for the cheaper consumables costs
You certainly won’t be sorry moving to the BBK, I’ve been running an AP BBK for the last four years on my track car and the performance is immense,
As it happens I also run the motul fluid and have zero issues, and I really do lean on the brakes very heavily.
Your only challenge now will be recalibrating your braking points with the new kit fitted, fun times ahead :-)
1 hour ago, BOBEL said:
Your only challenge now will be recalibrating your braking points with the new kit fitted, fun times ahead 🙂
Haha, I was literally thinking this earlier!
2 minutes ago, BRZ-123 said:
Well done Jeff. Now look forward to even better Bedford times. By the way, how much did it lighten the pocket by emoji2.png
With the pads and fluid I sourced myself (as I didn't want the ds2500's) it came to £1820 as I paid a little extra for the red calipers and curved internal veins on the discs
I've been using duct tape to block my oil cooler during winter but decided it was time for something a little less ghetto.
I had a sheet of perspex in the garage so decided I'd cut that to shape, add some insulation foam to the rear and give that a try. I'll get a piece made in polycarbonate once I'm happy it works ok, with the size, etcIMG_20201028_103244__01.jpg.85025dab2b0c1587a874174f938a1123.jpg
I got my Rayland BBK fitted yesterday at Rogue Motorsport. While fitting Mat found that one of my Whiteline roll centre correction kit boots had failed so that was also replaced.
Bedding the pads in showed the stopping power of the PFC.11 is stupidly good. Look forward to getting to try them on track at the club trackday on November 21st (Covid permitting).
Finally, an updated modifications list as I had to sort one out for renewing my insurance.
17x8.5" Do-Luck Double Six wheels powder coated red with 225/45/17 Nokian WRA4 winter tyres
18x9.5" Enkei RPF1 wheels with 245/35/18 Maxxis Victra Sport VS5 tyres
17x9" Konig Freeform wheels with 255/40/17 Accelera 651 Sport tyres
Maxgaurd Racegaurd Composites steel locking wheel nuts
Toyota badges removed and front and rear Toyota badge replaced with a custom Batman logo
Red flocked binnacle cover
Red flocked dashboard panel
Whiteline positive shift bush
Ecutek Remap
HKS oil filler cap
TRD Door stabiliser kit
Japspeed front carbon strutbrace
Beatrush master cylinder brace
Commune DIY wooden shift knob
Premiuim mats red carpet mats
Mtec shift springs
Perrin rear gear shift bush
Moton Club-sport coil overs (lowered approximately 40mm) with Eibach ERS main and tender springs
Whiteline front adjustable anti-roll bar
Whiteline rear adjustable anti-roll bar
Moton front adjustable drop links
Voodoo13 rear adjustable drop links
Whiteline rear anti-roll bar mount braces
Whiteline rear upper camber bushes
Legsport Clubsport carbon duckbill spoiler
TRD wing fins
Custom headlight adjuster for lowered cars
Cusco rear carbon strutbrace and modified boot mat
Cusco radiator cap
Whiteline subframe insert bushes
Whiteline front positive castor bushes
Super-pro rear diff insert bushes
Porsche 911 GT3 front arm brake ducts
AP Racing red front calipers
PFC.11 front brake pads
PFC.08 rear brake pads
Hel brake hoses
Reyland 330mm Jhook discs with curved interior cooling veins
Stoptech centric rear discs
Motul RBF660 brake fluid
Perrin cam solenoid guards
Valenti smoked rear lights
Valenti smoked centre light
LED side repeaters
Rogue Motorsport EL longtube manifold
HKS Hi-Power Spec-L exhaust
Hel / setrab 19 row oil cooler
Shift solutions front and rear tow hooks (used for trackdays)
SPA digital oil temperature and pressure gauge
Block8head dash mounted gauge pod
TRD front canards
White led boot bulb
Red led cabin bulb
Cusco accelerator pedal
HKS Suction Kit reloaded in custom Rogue Motorsport intake box with intake pipe wrapped in DEI reflect-a-gold
ARP wheel studs
Cusco magnetic sump plug
Cusco steering rack brace kit
Cusco rear member brace
Cosworth sump baffle plate
Varis Cooling System 2 carbon bonnet
Interior silver trim swapped for JDM black trim
Autofactory intake scoop
Sti side skirts
Versus engineering cam plate (to be fitted)
Verus splitter, carbon end plates and race upgrade
Verus Diffuser
Custom dashboard toggle switch panel
Third brake light lowering kit
Schroth Asm 3 harness for trackday use
Cobra Nogaro drivers bucket seat custom trimmed with red houndstooth
Greddy extra capacity diff cover
Weir Performance 4.88 final drive
Tegiwa sequential shift light
Eonon replacement Android headunit
STi rear bumper spats
Finally AP buddies at last, just to convince [mention=3357]willclarke[/mention] now.....
Haha, dont hold your breath - its pretty far down my list!
Sent from my Pixel 4 using Tapatalk
