Can anyone recommend a suitable set of wheel nuts to use for fitting a set of Rays wheels. I understand the OEM nuts aren't suitable.
Not looking to spend a fortune, but not wanting to skimp either.
I did see these on the Amber performance site: https://www.amber-performance.co.uk/product.php?xProd=25519&xSec=8578
Ta in advance.
If you don't want to spend a fortune on racing nuts, these might interest you :) RAYS Steel nuts. We are expecting them to be back in stock at some point this week. I can offer 20% Discount on those until 23:59 tonight.
https://www.part-box.com/rays-steel-locking-wheel-nuts-m12x1-25-black-17hnlm12x1-25-5hbk?search=rays nuts&description=true
+1 for those - proper nuts that you know will fit and being Ray's they're quality items.
Actually OEM lugnuts are just like most common aftermarket lugnuts, of conical seat, 60degree taper. So if not to spend a fortune .. you can use stock lugnuts. :)
Unless they are not suitable for lacking Ray's logo :)
+2 as the steel wheel nuts last really well if air guns are used. Also Rays wheels, Rays nuts. :)
I've had these on my car for four years now.
The only issue would be if the wheels have very narrow holes above the seats - you might not get a socket in on the standard nuts, so you'd need "tuner nuts" which have an internal spline drive.
Perfect, thanks should I call you to order?
It's okay, just use this coupon GT86CLUB10 when ordering online. :)
