GT1986 10 Report post Posted August 1, 2018 Hi All, recently just joined and have had my GT86 about 8 months now, love the car. I have a query hopefully some of you maybe able to help with or to just tell me its me Lol. I have the ECUTEK remap, on a couple of occasions when giving it some welly in 2nd and I change to 3rd when I lift the clutch and the car engages 3rd it cuts out briefly for a second or 2 like I have hit the rev limiter. I'm due to have some more work done on the car and another remap so will ask the guys when there. Just wondering if maybe 2nd has a higher rev limit than 3rd or something like that and this causes it? Not had it happen in any other gear, and I don't actually hit the limiter in 2nd the car only cuts out after the gear change and it registers 3rd. Anyone else had this or is it something I'm doing inadvertently? Many thanks. Share this post Link to post Share on other sites
Angelina 82 Report post Posted August 1, 2018 Hi All, recently just joined and have had my GT86 about 8 months now, love the car. I have a query hopefully some of you maybe able to help with or to just tell me its me Lol. I have the ECUTEK remap, on a couple of occasions when giving it some welly in 2nd and I change to 3rd when I lift the clutch and the car engages 3rd it cuts out briefly for a second or 2 like I have hit the rev limiter. I'm due to have some more work done on the car and another remap so will ask the guys when there. Just wondering if maybe 2nd has a higher rev limit than 3rd or something like that and this causes it? Not had it happen in any other gear, and I don't actually hit the limiter in 2nd the car only cuts out after the gear change and it registers 3rd. Anyone else had this or is it something I'm doing inadvertently? Many thanks.Have taken mine to rev limiter in all gears. No problem. Standard set up.Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
GT1986 10 Report post Posted August 1, 2018 I think i'll try changing to Map 1 for a few days (performance only) and see if it still does the same without the other features full throttle shift etc being active. 1 Angelina reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted August 1, 2018 It might be the auto-blip or flat foot shifting getting confused. If it's fine in map 1 then that seems likely. Share this post Link to post Share on other sites
MartinT 514 Report post Posted August 1, 2018 I use map 2 (auto-blip) and it does do that occasionally. I always thought it was traction control getting a little sensitive about the sudden application of the clutch together with throttle that does it. EDIT: auto-blip shouldn't apply when changing up. Share this post Link to post Share on other sites
GT1986 10 Report post Posted August 1, 2018 Thanks for the replies all, i'll keep you posted with how it behaves on Map 1 and what the tuners say when I'm there later in the month. Hopefully its just a case of it getting confused with my driving style and everything will be ok on Map 1... Share this post Link to post Share on other sites
surrey86 352 Report post Posted August 4, 2018 Are you on Primacies still? Sounds a bit like traction control. Share this post Link to post Share on other sites
Paul 442 Report post Posted August 4, 2018 It's flat foot shifting. I used to have this all the time. What happens is you're pressing down on the clutch but the throttle pedal is still in the range where the car thinks your foot is flat (it's got a margin for error so even if pedal isn't quite on the floor the ecu interprets as flat out). The map feature believes you're about to flat foot shift, and cuts the power so you don't blast through the red line as the gear change occurs, but because you're engaging the clutch to do a normal shift it all goes wrong and you end up lurching forwards for half a second before you complete gear change, hit the throttle and the car sorts itself out. If you shift to the power-only map you'll find the issue stops. Share this post Link to post Share on other sites
MartinT 514 Report post Posted August 4, 2018 I think it's traction control. Happens in Map 1, too.Sent from my LG-Q6 using Tapatalk Share this post Link to post Share on other sites
GT1986 10 Report post Posted August 14, 2018 Hi all, I've had no issues on Map 1 whatsoever. I was down at tuners yesterday getting a small bit of work done and brought it up during remap. He pretty much described it the same as Paul above. Basically flat foot shifting is throwing a wobbly with my clutch control and me not flat foot shifting when its expecting me to. I'm just glad its nothing wrong with the car I will keep it map 1 from now on until I fancy a play Thanks again for all the comments, hopefully this will help someone else if they encounter it. Cheers, Gary. Share this post Link to post Share on other sites
Angelina 82 Report post Posted August 14, 2018 Have taken mine to rev limiter in all gears. No problem. Standard set up.Sent from my iPad using TapatalkMe too Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
Paul 442 Report post Posted August 14, 2018 42 minutes ago, GT1986 said: Hi all, I've had no issues on Map 1 whatsoever. I was down at tuners yesterday getting a small bit of work done and brought it up during remap. He pretty much described it the same as Paul above. Basically flat foot shifting is throwing a wobbly with my clutch control and me not flat foot shifting when its expecting me to. I'm just glad its nothing wrong with the car I will keep it map 1 from now on until I fancy a play Thanks again for all the comments, hopefully this will help someone else if they encounter it. Cheers, Gary. No worries. I intend to get flat foot shifting turned off when I get the car mapped again. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted August 14, 2018 2 hours ago, GT1986 said: Basically flat foot shifting is throwing a wobbly with my clutch control and me not flat foot shifting when its expecting me to. I'm just glad its nothing wrong with the car I will keep it map 1 from now on until I fancy a play Flat foot shifting is a shite idea. I had it on a map (still do) tried it once or twice on track, but couldn't bring myself to do that to my car, so never used it since. Share this post Link to post Share on other sites
Angelina 82 Report post Posted August 21, 2018 Me too Sent from my iPad using TapatalkOnce I got confident, was rude not too. Not in UK public road though Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
