alucardo 55 Report post Posted March 13, 2018 I have purchased the kit a week ago but since driving it recently both sides of the car have started to rattle. I have noticed the anti rattle clip is easily moveable using just a finger which allows the pad to move slightly which is what I think is causing the rattle. This is on both sides. Video included. @Lauren @will300 @Ade Do your clips move so easily? Share this post Link to post Share on other sites
will300 812 Report post Posted March 13, 2018 The anti rattle clip is the wrong way round, it can't put any pressure on the pads like that.Sent from my Pixel using Tapatalk 3 Ade, alucardo and Lowe reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted March 13, 2018 Will is correct. Its upside down, it should be putting a constant pressure on the pads. https://www.apracing.com/drawings/CP9200-1CD.pdf 1 alucardo reacted to this Share this post Link to post Share on other sites
alucardo 55 Report post Posted March 13, 2018 Thanks for replying @Ade @will300 . I will get them switched round ASAP sadly not today but will post up when done. Share this post Link to post Share on other sites
Ade 517 Report post Posted March 13, 2018 Thanks for replying [mention=299]Ade[/mention] [mention=247]will300[/mention] . I will get them switched round ASAP sadly not today but will post up when done.It's an easy job. Just undo the middle bolt and flip it. Make sure you use appropriate torque setting on it and loctite if AP recommend.Sent from my SM-G935F using Tapatalk Share this post Link to post Share on other sites
surrey86 352 Report post Posted March 13, 2018 You're having a bit of hassle with those brakes. Even by the law of averages you'd expect half of it to be fitted right way around. 1 Ade reacted to this Share this post Link to post Share on other sites
