Nicebiscuit 655 Report post Posted August 21, 2017 Nicebiscuit: probably also no electric lights for sunscreens, no seat heating, no foglights? True re seat heating but did all the standard spec cars with fabric seats have that? I've got fog lights. No idea about the visors probably never checked! :-D Basically there's nothing I'd miss... Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Lauren 2259 Report post Posted August 22, 2017 Heated seats were a £1600 option. They are still an option between the stock car and the Pro. Share this post Link to post Share on other sites
NEIL PURVIS 1 Report post Posted November 28, 2017 I think i know whats happened i brought my car back from South Africa last year low spec all being in KPH , For the SVA test it obviously needed to be in MPH . I bought a UK cluster which wouldnt work because of immobilizer so just changed the face plate from the clocks so i had a MPH reading ( analog ) it got me through the test and on the road . I am looking at attempting to modify the circuit board to swop the 10 pin plug which is missing on the low spec for the digital speedo to push into . Will let you know how i get along if it works i will have to replace switches to change between KPH and MPH 1 Ridowh reacted to this Share this post Link to post Share on other sites
Ridowh 8 Report post Posted July 31, 2018 I have just imported my GTS86 from Australia (and just got it yesterday, finally, after it had been ‘randomly’ checked by Interpol before DVLA would issue a registration). It’s a 2015 model (with the sharks fin aerial), registered there in Aug 2014. I waited specifically for the new model to come through so got one of the earliest ones to hit Australia. In order to pass the IVA test it needed a new fascia showing both mph and kmh on the analogue dial. Unfortunately it still shows kmh on the central digital display, and the button (that toggles mph and kmh on the U.K. version) is just an inoperable (and immovable) button. Do any members know if the circuitry that should sit behind this button on the U.K. model still exists, and therefore all that is required is an operable button to toggle the central digital display readout? My odometer also still shows as km and I’d like to change that as well, however that isn’t as important to me. Many thanks in advance, Septic Share this post Link to post Share on other sites
