Mike@TD.co.uk
MTEC Springs & Gearknobs In Stock At Tuning Developments
Hi all,
As mentioned in our demo car thread, we now have the MTEC range of parts in stock for the GT86 & BRZ.
We have the shifter springs, clutch springs and also the gearknobs all in stock.
We can offer installation at the workshop or these are all available for mail order also if preferred.
Shifter Springs: £38.99
Clutch Spring: £32.99
Gearknob: £95.99
Some photos of the different parts:
Above: Gearknob
Above: Shifter Springs
Above: Clutch Spring
Mike
If having the shifter springs installed on their own it'd be £59.99 inc VAT for fitting.
If we're doing other works at the same time we can tie the cost of these in with other works to reduce the labour cost.
Mike
8 minutes ago, Mike@TD.co.uk said:
I'd rather you than me if doing it on a driveway :) fiddly is probably the best word to use.
Thanks
Mike
Yeah they look it.
13 hours ago, KevinA said:
Do the M Tec springs do the same as the Whiteline shift bush ?
How do you mean Kev? You can run both items if that is what you're asking?
We run the powerflex bush in ours and since adding the shifter springs it has made the shift nicer again :)
Thanks
Mike
Driven my car for about 300miles since the install of clutch and shift springs. I can say they are both excellent!
Clutch spring - a bit heavier than OEM, not going to tire you out. It gives  much better feedback when you're at the biting point!
Shift springs - JUST DO IT! Transmission is SO smooth, everything just clicks in like magical butter! (I also have the Whiteline positive shift bush to support this)
On 06/12/2016 at 10:40 AM, rob275 said:
I hate doing anything on the driveway full stop, plus I get covered in f*cking sand.
THE ANTS!!!! :lol:
Think I'm gonna get me some of these springs
